Has any of you builders tried the Precision Devices Prestige Series - PD 2450 driver for a DIY Sub??
Hears the link http://www.papl.co.uk/asps/ShowDetails.asp?id=17
Im very interested in using it in my next project ;-)
Any comments on this driver?
Cheers
Stewart.
Cheers
Stewart.
Hope you have a HUGE room if you decide to build it...
Your system will be faster and go lower if you consider using the Bag End ELF technology instead... I've just replied to another sub post here:
http://www.diyaudio.com/forums/showthread.php?s=&postid=30925#post30925
Specifically, check out the links on the ELF technology...
If you build it, good luck. Hope your house is built well....
And no, I don't work for Bag End...
Steve
Steve
