I have been ripping cds to 44100/16 bit flac files for my PC with Asus Xonar Essence and am thinking that I should convert these files to 44100/24bit flac, which should be basically lossless, so that the digital volume control has enough bits to work on without causing significant rounding errors.
The PC is running Ubuntu 10.10 and 100% volume causes distortion
Anyone with any thoughts about this?
Agreed that I cannot add resolution. I am thinking that the card is capable of 24 bit (20 bit in practice) resolution, so if I set the volume to about 0.7 to avoid distortions, I don't want the OS software multiplying a 16 bit value by some constant and truncating to 16 bit again.
A -60dB sinewave is already horribly quantised in 16 bit format. If the card actually is working as 24 bit, then no problem as this waveform will be fairly accurately scaled.
Isn't the volume control implemented in the main cpu, not in the DAC these days?
Even if the volume control was done in software (e.g. fade-in/out in modern players), the software uses its internal sample format (mostly float or int32 or int16 for older programs). The input format is converted to the internal format first and futher processing is independent of the original sample length.
It all depends on your playback chain. It can either use software volume regulation (softvol plugin of alsa, software volume in mplayer when configured, software volume in pulseaudio when configured), or the volume control provided by the driver and operated via corresponding alsa-lib API (mplayer when configured, pulseaudio when configured, various mixer gui applets). The driver transmits the commands further to the sound card (DAC chip or analog volume regulation chip on old cards or Revo5.1
First of all, isn't this card running in 32 bit? Anyways i don't think your bit rate is the problem...
Most low-end equipment will distort even before the 0dbfs limit. Thats why mastering engineers often export their mixes a -0.5dbfs. So pushing your card's output over that threshold is probably causing the problem.
Second of all, i don't understand why you need to set the output so loud! I never tryed to put my volume that loud cause is was afraid to kill my headphones. (Im using the beyerdynamics DT 770 pro 80Ohms. Good headphone listening level is around -20dbfs. And if you need higher volume in the speakers, put the volume up on the amp.
I hope this helps!
-Max
I hope this helps!
-Max
- PC Based
- 24 bit vs 16 bit for Jajuk
