Since I managed to get a free Revolution 7.1 sound card, I have been entertaining the idea of tapping the I2S directly out of the Envy24HT IC. I have found the datasheet for it and the right pins, but as the EEPROM is set at the moment it is configured for an AKM DAC and outputs 24 bit left justified I2S.
This would not be a problem except as a quick and cheap experiment I wanted to go right into the dreaded TDA1543, which of course is 16 bit. The datasheet for TDA1543 says it "accepts input serial data formats in two's complement with any bit length". However, the only timing diagram example shows a 16 bit input. I would be using it for only 16 bit pcm so I would think the Envy24 pads the rest of the word with zeros. Somehow though, I don't see how this could work. Is there any way to basically trim the zeros without editing the EEPROM to set the output to 16 bit to start? I guess you could demultiplex the serial data and use some logic but if that is the case I might as well just go DF1704 - PCM1704 to start.
Thanks,
Chris
Thanks,
Chris
