Does anybody know of sources for this commonly used diffuser/absorber?
I'm looking to make the DIY version of 8th Nerve's new Adapt Response Controllers for taming corner distortions.
Essentially, these treatments are simply 2" rigid high density fiberglass in wedge-shaped wooden frames. The room facing side is supposed to be solid/reflective, while the fiberglass is mounted on the backside. Any thin fabric can be stretched over the frames and/or the fronts can be painted or veneered.
As the pictures show, a small gap is supposed to exist between the panels and the associated walls to allow sound in.
