greeting to everyone
I want to build a 1KW SMPS power supply. The plan is to use a PFC preregulator followed by some form of isolation type regulator. I could use some help.
Fortunately, I've found 2 PFC reference designs from On semi that are each 1KW. The first uses the NCP1650 average mode pfc controller (and there is an available eval board), while the second used the MC33262 in critical conduction mode (no eval board available). It looks like either of these would work for me, but am interested in your opinions.
OK, so what about converting the PFC output down? I'm considering a few options:
1) A single supply for the entire 1KW
2) Multiple supplies in parallel
3) Multiple supplies, where each powers a different amplifier or group of amplifiers
Maybe some design details are needed here - the design is for a digital amplifier, probably 5.1 style. I believe the amps will use around 30-35 volts each. There is also some low voltage needs (microprocessor, for example).
Getting back to the supply configurations, I like option 1. My reseach indicates that a half bridge push pull setup would be a good choice. I'm having a tough time findind a good reference for this, however. Also, I am a little concerned about the danger at that power level.
Option 2 concerns me because I am not certain how to put power supplies in parallel without getting into load share problems. I see from other posts that there may be a synchronization problem as well.
Option 3 is neat, in that it is modular and expandable.
Any help or comments?
thanks
gene
thanks
gene
