I am confused about 1626....
In the datasheet, like this
1626 datasheet
It's plate Input max wat is 6.25W and plate disspation is 5W.
If I set the max plate watt is 5.5W, the output power of 1626 is less than 0.7W ( even less than 0.6W)
If I set in 6.25W, I didn't get more than 0.7W.
But.....
I want to make a SE Amp for 1626. The crude estimation, 1626 should be reach in 1W ( 20% of max plate disspation watt).
Have any work point is better than I set in plate 200V, bias -24V.
1626 datasheet
But.....
