Blue Aran sometimes have a few 4ohm PrecisionDevices
But none with the high Xmax of BMS
I hope you wont be near those woofers, playing that loud
Why? I like bass.
Is there a woofer like the BMW 15n850 with say dual 4ohm voice coil or just a single 4ohm out there?
I was very impressed with how well it simulates, and then it has 13mm xmax. But I need lower impedance to be able to use that xmax.
Ideas?
There's a Ciare 12" equivalent to the 12.00SW but with a dual 4 ohm coil, with 11.5mm Xmax:
CIARE 12.00SWDCNDW - U.K. International Cyberstore
Obviously lower efficiency and Xmax but might do the job, depending what you're looking for.
mail them.
im sure ive seen some 4 ohm bms drivers out there.
edit/
the bms 15 840 is also in 4 ohm ,or the bms 18 850 is also in 4 ohm
bms 15 840
edit/
bms 15 840
mail them.
Yes, but not the 15N850, according to the BMS website this is 8 ohm only.
for the 8ohm nominal, specs says 5ohm dc/Re
imagine dc/Re for a 4ohm nominal
your amp would need to be fit fore 2ohm load
- Subwoofers
- 15" woofer like BMS 15n850 but 4ohm
