It has been awhile. I haven't done much with the 6bm8 amp yet but I do have the 12ax7 tubes for the RIAA phono stage.
I don't have the HV 250+ supply yet but I want/need to create a RIAA phono preamp for my R25XT magnetic cartridge as my only preamp in my SSM-1250 DJ mixer is kaput. (the mixer got damaged by a power surge that left skid marks on the audio board. some traces are disintegrated. Might even tubeify the thing later on.
I want to build a RIAA preamp that uses 12Vdc or 24vdc power supply to provide preamp/riaa for my cartridge. Is there such a circuit? Looked on the net but I didn't see a low voltage RIAA circuit but I do have a few standard 250+v ones that I wonder if I could modify to do the job.
I think there was a sub mini phono pre on the board somewhere that used a very low B+. By koifarm maybe?
Here's what I was thinking of:
http://www.diyaudio.com/forums/analogue-source/255041-mini-me-second-edition-tube-phono-preamp.html
48V b+
48V b+
Jan Didden's Linear Audio volume 10 has a relevant article by Ronald Quan. Well worth the read if low voltage tube operation is a subject of interest.
Just a note, there are 12v dc-dc boosters that can produce high 250+. I saw several in Ebay However, I want to keep it all tube. I could try a space-charge tube but, right now I got 12ax7 tubes. Which space charge tube is similar to a 12ax7?
Yes there is :It has been awhile. I haven't done much with the 6bm8 amp yet but I do have the 12ax7 tubes for the RIAA phono stage.
DC10 32V to DC ±45 390V 780V Dual Output Adjustable Converter Capacity Charger | eBay
here's a list of low voltage tubes:
Space Charge and Other Low-Voltage Tubes
i don't think any have the gain of 12ax7 (mu=100)
- Tubes / Valves
- 12v/24v RIAA MM preamp
