12B4 Updates
ray bronk
2005-08-22 7:10 am
hi all,
Well I remember on one of the 12B4A threads reading about putting together one of those preamps using only 5 parts, including the power supply. Now, being blind, can't see the schems. So could someone at least verbally describe the circuit? I might have to perf board this project. I can solder. This is one Place where my old trusty Weller soldering gun will come in handy.
Francois G
2004-06-16 8:36 pm
Illinois
The plate resistor is 12kohm, cathode is 500ohm and B+ of 260VDC. This gives a 15 ma plate current.
I built this circuit and just love the sound. I have been using it in my main system for 15 months and had no itch yet to replace it. Actually I planned to use a really good CCS as load, but tried the resistor first to get everything working. Well, I still have those CCs lying around - even with the lowly resistor it sounded that good that I did not want to bother with the CCS.
One caution -- depending on your needs you may find the gain low - I did not have any problem feeding my Eico HF87, which has high gain. I think the gain is around 3-4 times
And you will need a very quiet power supply.
I basically built the "Etude" described here http://www.diyparadise.com/etude.html
Good luck.
Francois
