12" VOLFENHAG subs, any good?
Haha, these were my first subs I ever owned. I used a Bazooka Class D amp to drive them and to be honest, they worked well in a small sealed box.
I had a friend melt the voice coils (something smelled burnt) on his two but mine worked for a long time.
Have fun with them man!
I started with a sealed box purchased from Best Buy, it was given to me for free.
I then bought this pink foam from Home Depot and I believe I used to layers on the back of the box. Just to give you an idea of the size of the box I used.
The Volfenhags I had were the red coned ones, DVC, rated for 1000W.
I wouldn't put the foam blocks in it unless you feel you made the box too big. I am assuming since the box fits under your back seat it is pretty small. Other than to reduce the size of the box the foam blocks had no sonic benefit
I did use polyfil in the box but I am aprehensive to recommend it as I do not know if it has any benefit either.
