Hi
I did a modification of this pot for a Fender Twin because the pot was damaged. I connected two 50ohms 1/2W resistors to each side of the filament terminals to ground. It worked OK for a while without any hum but then the 2 resistors burnt out. Do I need to put in higher power rated resistors or can I do away with this 100ohm pot, if the amplifier doesn't hum.
