I was planning on using this knob
Medium Plastic Receiver / Amp Knob 0.61" - Silver
With this potentiometer
25K Audio Taper Potentiometer 1/4" Shaft
But I wasn't sure if there's a fit difference since the pot is 1/4in while the knob is 6mm...I assume it would work but wanted to double check before I screw it up haha
The description does call attention to this
For use with 6 mm half-round shaft, small indicator notch....
- 1/4in shaft and 6mm knob fit question?
