Grounded grid preamp voltages
I have a Grounded Grid preamp. The board is from Analog Metric in Hong Kong. When checking the voltages without tubes the voltages are substantially higher than specified.
HT is 16,9V. It is supposed to be 12,6V
+200V is 236v
-200V is 238V
All components seem to be the correct ones (I have however not measured them).
Is this big difference to be expected, or is something wrong?
At first powering, I suggest to use a current limited power supply: remove the fuse in the primary of the PSU and wire there a filament lamp 1 to 3 times bigger power than the DUT. If anything go wrong, the lamp will bright increasing its resistance and protecting all including you. Note that no lamp other than filament: no fluoro nor led.
If the 15V is the filament DC voltage, that might be a problem.
Is the regulator/heat sink for the filaments? You may have to draw a schematic.
The LT1085 regulator should be more than capable of doing the job.
Yes 15V is the filament.
The transformer I am using has 230V primary and secondaries are supposed to be 12,6V and 200V. Without load secondaries are 14V and 216V. My mains are 233V.
The preferred resistor values are R20 = 125R, and R21 = 1.135k.
This is to ensure that the regulator always has more than the minimum rated load current.
I would change both resistors to these values, so the regulation does not suffer.
V1A/B is called a cathode-coupled amplifier.
V1A is a cathode follower. V1B is a common grid amplifier.
The cathode of V1A couples the signal to the cathode of V1B.
The tube section loading the common grid stage is sometimes called a cascoded cathode follower.
Post 17 :
So you seemingly agree that the combination is called a differential amp,
in its classic form, but with a single output only (it can easily be converted
to balanced output). Both grids are input terminals, signal and feedback.
