Doubts about Aleph 3
Good morning everyone I'm dealing with the purchase of an Aleph 3 the seller tells me that it is all original capacitors but they are different: 6 have the black lid and 2 do not. Do you think it is possible that it came out of the factory like this or was it tampered with? Thank you
Nice detailed pictures would be best to confirm.
That being said, I am sure Pass Labs would be happy to give it a look over, test, etc…should you choose to ship it to them.
The Aleph 3 has been around since the early 90’s and is a single ended Class A design. Bias current runs high, is continuous and does strain several of the components over time (20 years +/-).
Although stable, parts failures can and will happen (ps filter capacitors, MOSFETS, etc…). It would be best to rectify these issues before they happen. Of course this is dependent how long the Aleph 3 you are looking to purchase was in use. If it stayed in the storage closet for 10 years well…
Best,
Anand.
This is photo…...
I've seen photos of recent Pass Labs builds with Cornell Dubilier caps so I would
consider those. You'll have to make sure they physically fit on the PCB so best
to measure the originals first. I would stick with a similar capacitance value
(say 22000 uF each) but go with 105C caps.
You'll have to make sure they physically fit on the PCB so best to measure the originals first.
They are 30mm and no gaps, which is pretty limiting as all I could find with a higher voltage (I’d have preferred to have gone for 35V) were all 35mm so wouldn’t fit. The height is no issue, all modern caps I looked at were shorter than the original Panasonics. I ended up going for 105C Vishays (22000uF 25V) as they were actually in stock at RS! It is amazing how many caps aren’t at present, many places having lead times well into next year. I’ve no idea if I made a good or bad cap choice, but the amp certainly works without fire or anything! I replaced the 220uF caps with Panasonics while I was in there. Old ones seemed fine, though I don’t have an ESR meter to really check. No leaks, bulges, and they were all pretty much bang on value. It was the PSU ones that looked a bit sick.
