nearly impossible to find 2SK3497
any FQH44N 20S
FQA28N15 7S
could do the trick?
or even a irfp150?
any FQH44N 20S
FQA28N15 7S
could do the trick?
or even a irfp150?
Thanks for postulating a DC variant and sharing it Patrick!!!
A simple IRFP240 version will work but the IRFP150 is even better (than the IRFP240).
Something in the back of my mind keeps asking me why would Papa go single rail and coupling caps for the F8 when it is a small change from the J2 to this? Did he leave the door open on purpose or are there undiscovered mysteries and a trail of clues left behind still?
To do the DC version properly, you need to change the feedback network resistor values to suit the JFET Idss.
OK for DIY, but not necessarily what you want to do in production.
Patrick
Patrick
would it be possible to do a DC version "a la UDNESS" using a N Jfet (2sk209) and P mosfets at output FQA9P25?
The UDNeSS has the advantage that it has differential input.
So you can play with inverted input signal and reversed speaker polarity to get reversed H2 phase.
This you cannot do with a "F8" variant.
Patrick
Patrick
As a first step in Spice, I've been trying for a few days to simulate a version with readily available components from the work of Patrick. However, that is far from finished, maybe someone here would like and above all know more to develop this further?
Best wishes
Jens
- First Watt F8
