crippled F4 — huh?
uhm...
F4 without the input buffer?
BA3 OS is in fact as crippled F4 (meaning - non buffered input)
you'll find somewhere info from Man with Silver Beard himself , about crippled input impedance ;
I hope I'm clear enough now , so don't huh! , please
:clown:
huh?
f4 build using auto formers for my frontend and am going to be removing the jfets at the input (crippled as they say)
what I meant - I was joking when I titled it "Crippled" , not you mocking ..... 🙂
in cases when preceding stage is having enough Cojones (low Rout), some people find that saving two pairs of JFets for something else is welcome
and - sometimes superfluous stage is really superfluous ...... even if you can't hear it's really better without unnecessary buffer stage, it's good enough if you're sure that it isn't worse
if buffers aren't needed, does it improve anything to omit them or is it just pure joy?
I had 4 power follower amplifiers. The F4 the only one with a buffer on input.
It edges out all other three without input buffers. Does it sound better because it has a buffered input? Maybe, maybe not. It does stage match better, so it might interface better with the preamp stage. That's the way I see it, but someone will certainly disagree.
Mostly depends on what you have to drive the output stage.
If it's plenty beefy then it might actually sound better without jfet buffers.
Designing it the way Papa did gives a guaranteed good result. Doing it the other way could be better or worse depending on the equipment driving it, which is not an ideal situation for a commercial product.
DIY is a totally different ball game.
I would like to use my BA-3 output stage as a current buffer for some smaller amps (300B tube amp and F3 Clone). I am thinking these amps would be "plenty beefy" to run without an input buffer on the BA-3 output stage, looking for correction/confirmation. Connections would be as shown in image below. Thanks!
I connected the tube amp to the mids and tweeters of my 3 way speaker and to the BA-3 output stage as shown for the right channel in the image in post 13. The mid, tweeter and passive crossover load the tube amp, but for the bass frequencies, the impedance of the high pass filter for the mid is probably quite a bit higher than optimum for my output transformer. I was thinking this was ok, but I am always happy to be educated. It sounds good, any other problem to be looking for?
