Hello folks,
I´m looking for a stereo tube preamp to build. I know theres a lot of projects in the internet and here on this forum, but I´m newbie on this and need some help to decide which one will be the best choice for me.
I gonna use this for audio recording. Will feed it with line signal, and go back to an AD converter to record the audio with the tube color.
What I need:
*Balanced inputs and outputs (it´s not a must, but would be great to have it)
*stereo preamp
*I need something with a full range response... 20hz to 20k
*I want a tube warmth but I need it to be as clean as possible. (Lowest possible noise)
*I´m looking for fat low end and smooth highs sound
*I like the sound of ECC88s. A project with these would be great, but also open for suggestions.
*I´m and experienced audio engineer but newbie on electronics. Better if there´s a kit avaible or some instructions to build.
Hope you guys can help me
Thank u so much!
What I need:
*stereo preamp
Thank u so much!
Tubes has no color or "warmth".Hello folks,
What I need:
*stereo preamp
Thank u so much!
Any hifi amp will have full response in audio range and will only have
as much low end (and high end) as the program material has.
Ok, but look tubes are not exactly precise components, it changes the sound and add harmonic distortion. Those changes and distortion are what I call "color" or "warmth". Tubes are definitely not a fully transparent piece that the signal goes out exactly the way it comes in. And that´s what i´m looking for.
I mentioned about the full range response because there´s some tube preamps made for instruments and those can have some filtered low end.
My friend Stu has what you're looking for:
SYclotron Audio | Preamps
No "by guess or by gosh" design, just solid engineering.
Thank you! I gonna check this!
Tubes _may_ change the sound and add distortion, but then we are notOk, but look tubes are not exactly precise components, it changes the sound and add harmonic distortion. Those changes and distortion are what I call "color" or "warmth". Tubes are definitely not a fully transparent piece that the signal goes out exactly the way it comes in. And that´s what i´m looking for.
talking about hifi ( or neutral ) amps.
There is nothing wrong with coloring or changing the sound that emanates
from a source, but it is not neutral or transparent, it's according to one's taste.
Well built tube amps will not add sweetness or any other type of distortion,
instead they will replicate the source. Any amp that are used at it's limits will
change the sound, here tubeamps is usually behaving differently then sandamps.
Ok right, i understand. But what im looking for is some tube preamp that actually color the sound. Specialy something that help the signal sounds Fuller, and with a smooth top end. Can u suggest me something?
You want a single-ended circuit with transformers for input and output. Single-ended gives you the tube 'distortion signature' or sound (no harmonic cancellation as would occur in a balanced circuit) and the transformers will give you balanced (or single ended) input and outputs.
Thanks for the reply!
Do you know where can i start? Is there some diy kits or pcb for a project such u have described?
Thank you!
He is quite correct about that. You can add input and output transformers to just about any DIY design out there.
Great! And do you have any suggestion for a diy project that fits my needs?
I would put input and output transformers around the preamp section of an old Fisher tube receiver. That would likely meet your needs reasonably well. I go out of my way to avoid 12AX7s in anything I build, and I don't really see a lot of new published preamp designs using them.
Hmm interesting. Fisher tube preamp? I gonna search It! Thanks!
Input transformer: your choice 1:1, 10k volume control, 6SN7 tube, output transformer lundahl 1680 8mA
Those Transformers are for the balanced ins and outs?
They are
Great, thanks! Gonna check those!
Does these Transformers can add some color?
Anything that adds phase changes (and group delay changes), frequency response changes, and distortion will add some color.
The questions are:
How much color?
Can you hear it?
For distortion that is generated by a small signal transformer, some causes are:
Magnetized core
DC offset from the prior circuit
Large signal levels
The questions are:
How much color?
Can you hear it?
Magnetized core
Large signal levels
The question is, how much color?
I gonna use this to add color to Full songs, stereo recording, then It has to be something subtle. The good tube processing i have tried makes music sound Fuller, and adds some body to the low end, makes the high end smoother. But of course in a subtle way... Nothing extreme.
Can u suggest me something for this purpose?
Thanks!
- Tubes / Valves
- Which is the best tube preamp for me?
