Babelfish M2/SEF amp
Should the new output be taken from the drain of Q2
and is the pinout looking down on Q2
G D S?
Thinking about doing the mod to my Toshiba M2
Bob
nope Bubba
for SEF, output taken directly from source of IRFP9240 (that one in negative rail)
pinout , numbers looking at you , legs down , from left, is always G-D-S
802804d1576597208-babelfish-m2-sef-amp-sef-final-png
Schaded M2 up and running
Using Schade 3.5k ohms.
Bias 1.4A
R6s 40k on one channel, 42k on the other
Wide and deep soundstage - tight bass - instruments well placed - smooth -very easy to listen with this amp.
Highly recommended if you don't have access to THF51s or 182s
Hats off to you ZM
Bob, don't forget to try both speaker polarities. 🙂
indra1
On my Tannoys changing polarities is interesting - there is a subtle difference - original polarity seems a bit warmer to me - sorry I am using a term that may be different for each individual - both are listenable - this may have to be integrated over more listening 😀
Still say that this would be a great amp for a person new to diy
N.B. that final development (well, up to my ability) is done in Babelfish M25/SET amp
today I'll do even that one slightly different, putting Schade to upper mosfet
though, only drawback, if it is drawback at all is that 2nd harmonic is positive ( when Schade is in lower rail) , so all you need is to flip speaker polarity to get negative one
construction wise, both cases are challenging in finding small mosfet ( for small Source follower, explained in mentioned thread) with lowish Ugs ; in case of Schade down, solved with TP2640, in case of Schade up, DN2540N5
post #20
