Buy - "Noiseless" Electronic load
Here is a very easy way to change (jumper):
Yes, thanks. What I was thinking is if a diode shall handle many amp.
While writing this reply, do I suddenly doubt what power I will get out of the sollution.
lets say two power suplys 30V at 30A, put in -30V to +30V configuration, do I then also get 60A?
If the psu's is in 0-60V do that also give 60A?
My reason for thinking about making a switch box, were that a diode with 60A, sounds like a lot of heat!! And instead of having to let the diode dangle in the air, why not build a simple alu box with a simple switch, and thereby just flicker the switch when I need to change the setup?
Diode rated current must be larger then power supply rated output current.
Series connected power supplies have a rated current as in an only one.
Ok yes that sounds logical!
Am I right in assuming that it is better to get a massive wary high current diode, gives less heat, so it is better to go over board when buying that diode?
How would the power supply's react the diodes voltage drop, do you not end up with i.e. a difference in ground at 1.6V?
