I'm currently listening to an F1 borrowed from a friend. It truly is magic - driving 16ohm compression drivers through large horns - covering 460hz-20khz. Active system with an arc-welder doing bass duties (old-school Crown - awesome)
Its got me sold on First Watt. I absolutely love it.
Given the zero-availability of the F1- and based on reading and advice, the J2 might be my option. However,here is no chance for me to hear one before I place an order.
Can anyone familiar with both make some general comparisons or comments to help me out? I would really appreciate it.
The F1 is SO quiet, black. With the horn sensitivity at 110db, that is important. J2 has two gain stages vs 1 etc.
I welcome your thoughts.
Coelacanth
Coelacanth
is DIY an option for you? - it's easy to make F1 , considering that there is no unobtanium parts at all
if you found F1 pushed all your buttons , there is no way that J2 will do the same , without pains - as you said , when dealing with sensitivity of drivers so high , everything is critical , and even more
why - even if you buy J2 made by FW , which is properly made , there is possibility that you'll have worse S/N ratio when connected and interconnected , simply because there is a ton of gain in J2 comparing to F1
also - J2 is 2nd harmonic dominant , while F1 you found so nice is either 3rd dominant or so-so (depending of fact who made it)
so , just go and build it ...... or build any of recent shenanigans of our Michael Rothacher (MoFo) - again - your in good place with your hysteric squawker , making an amp for that is more easy than hard
if needed , I believe you will find F1 pcbs on forum , or files to make your own
Was the F1 you used a factory one or a DIY piece? Can you check with
the owner if it's the original mosfet version or whether it has the semisouth
jfet update.
If it is the mosfet version, then as the Mighty Zen Mod said, all parts are
readily available. Since it works so well for you, I suggest you try building
one.
jfet update.
one.
Thanks for the responses. It is great to know the DIY option exists for the F1 - certainly something I will look into.
The F1 I am borrowing is an original First Watt-built unit with mosfets. I listened to two albums last night - both live jazz recordings - not usually my thing - but the F1 was riveting. Scary real. Relaxing, then snap! a snare hit would make me leap out of my seat with a shot of adrenaline. Damn!
With the DIY thing acknowledged as a valid option, I'd still very much like to hear from people who have experience with both F1 and J2. My DSP can take care of a minor discrepancies, gain matching etc, but are these wildly different sounding amplifiers?
With thanks!
With thanks!
dunno for Dennis , but I did wrote from experience.....had both of them in various incarnations , it doesn't matter that majority of my listening with both was having amps in Ikebana style (bunch of parts on MDF plate)
Thanks for your comments Zen Mod.
Theres a J2 on ebay in australia at the mo... I had to delete my watched item reminder in case I succumbed to it.
Pass Labs J2 Power Amplifier in ex display condition | eBay
aspringv, maybe you should then add these to your ebay watchlist!!
THE GRYPHON PENDRAGON floorstanding speakers in excellent condition | eBay
I did it in 2011, look here
https://www.diyaudio.com/forums/pass-labs/169509-firstwatt-f1j-9.html#post2666130
sound was fascinating, getting offset and so on low was hard work.
Keep your hopes up Dennis, Papa said he is testing some USCi Jfets in new device.In that case the DIY route now require sourcing 4 semisouth jfets.
- F1 and J2 - anyone own both?
