X-ccs bosoz need more gain
Hi guy i just try to make some measures and i have just discovery that my x-ccs bosoz gain is only 2 or so (6db)
I compared its fft with my 6sn7 tube preamp ( i love his timbric),I'd likeit to amplify more (10db) and that had a predominance of second harmonic.
What are the elements that manage the gain ratio?
What can I do to manage the second harmonic distortion like I did with my F5 v2 turbo Power Amp?
To better interpret the values of the FFT 1Khz I also measured the sound card slot in 5,8db and 3,8db.
Later I performed the measurements on the X-ccs Bosoz.
My primary need, however, is trying to get more gain.
Please can you help me?
Thanks in advantage
Antonio
as I said , for increasing gain - decrease value of both source resistors
regarding miniscule gain - triple check values of resistors you put on pcb
regarding invoking nonsymmetry in circ (invoking 2nd) , few tricks :
-different values of source resistors
-different values of drain resistors
-different values for NFB resistors (4K7/47K)
different meaning - not equal values left vs. right side
edit: quick analysis of voltage points and currents in your schematic is showing that 680/68R resistors are correct
what is a way of driving the preamp : bal in/bal out or ..... ?
if you're keen of connecting output to gnd at all , then ground positive output , not negative
so , try it like this (using SE Input):
1. IN- grounded , none output grounded , use whichever OUT you want as SE hot
2. IN- grounded , OUT+ grounded , use OUT- as SE hot
choose which way you like more , and inform us what is gain in both cases
..... for now , only worse thing you didn't tried , is grounding all inputs and all outputs :clown:
Hi the picture show :
Righ channel= IN- grounded , OUT+ grounded , used OUT- as SE hot
Left channel= IN- grounded , OUT - grounded , used OUT+ as SE hot
In both cases, if not short-circuit the pole consideration not used to exit (out + or -out) depends on the case mentioned above, the exit used accordingly becomes slightly more low.
I tried with 1,957 Vin and 4,242 Vout so the gain is 2.16.
Tried also by taking the + and - poles simultaneously same result gain.
Tried r5 68//27 and no more gain
Tried short r16 4,7k and gain up only from 2,16 to 2,96
tried r17 47k//47k and gain down from 2,16 to 1,95
I can not figure out how to get more gain in this preamplifier!😡
OK, made some LTSpice sim
everything (voltages,currents on your schm) is by the book - when used balanced in/out , gain is something under 4V/V
when used SE in SE out, gain is aroind 2V/V , as you got
for more , decrease source resistors for Q1 and Q2
with 6R8 there (R5 and R6) , you'll get gain around 4V/V
with 2R2 (hopefully Q1 and Q2 are matched !) , gain should be 4.4V/V
and ....... that would be max with that circuit , without changing it too much and naming in then differently
all other values as per schematic
for 6R8 you can use ordinary 600mW metal film resistors
