HELP: TINA model of oscillator using 4093 not working. Desperate!!!
I'm trying to model a circuit that has a few 4093 NAND Schmitt triggers in it. I can't seem to figure out how to get the model working in TINA (Spice modeler from TI). I've seen the exact circuit modeled elsewhere on the web just fine, so I am really at my wits end here. I haven't modeled any logic circuits before now, so it could definitely be user error, but I am stumped.
PLEASE HELP!
Circuit and output are attached. It's right out of the datasheet! It should be a free running multivibrator but nothing is happening. I've included a timed switch so that pin 1 is pulled down to zero initially - that datasheet shows the transition low to high in case that was the source of the problem, but still nothing.
-Charlie
Ahhhhrrggggh. OK, I figured it out. I was simulating the circuit using the condition "zero initial values", which seemed to me to be the case since the circuit is "off" prior to simulation. If I just changed this to "use initial conditions" the circuit simulates as expected. Oddly enough, I haven't actually included any initial conditions for the circuit! How great is that, huh.
Anyway, now that I have much less hair remaining on my head, this annoyance has been solved.
