To all diy friends,
Please disregard post# 2276, today i found 1 open track on C pin of MJE15031, will have to correct that error tonight and repost the file again.
If anyone found some error please let me know so i can correct accordingly....
Thanks...
Wiljj78
With a lot of work mistakes are inevitable.
That's true Mr. Mile and real diyers will never give up till finishing line...
do the Hx design have to use supply voltage by factor 2
This H class design can be use for high power amps, something like this:
I can see they are mosfets, but other than that.... 😀
If you want +/-60V, and +/-120V you need 5 pairs of outputs and 5 pairs mosfets like IRFP240/9240.
Here's the files for HX-11 Ver. 3.3.
cool
thank you mister, you are true diy,
Nice Willy very nice. hey my man I'm putting together your version of AX-11 MKII and well if some one can help me out I will really appreciated, 😀 today I'm putting together must of the component I have on hand I just need to get me the transistor MPSA-92,BD679A,MJ15003/4,MJE15030/1, and resistors 4R7/1W and the emitter resistors 0.22/5W, so far is going well 🙂, here my question I do not have 331 caps, can I use 220pF or 180pF instead ?
Vargas
Vargas
Mr Mile, for HX 11
I have 2 transformers 25V-0-25V AC (~35V-0-35V DC) and
a 45V-0-45V AC (~63V-0-63V)
What transformers Voltages and VA do you recommend for Maximum.
Vargas
Wow... nice progress my dear Juan very nice... just one question i saw that yellow cap standing up high in front of MJE340 notification says 220p/250VAC... about 331 cap i suggest to go for 471 to compensate but let Mr. Mile to confirm what is the right replacement value.
thanks buddy! 😀 well I guess we should wait for him I really don't want to mess it up, it took me a long time to put it together today 😀 ,the yellow caps is just placed there as reference, not sure if I can use it or not just to see how it looks just that, I do not have many components but also I do not want to change a really important components with the wrong value and damge the circuit.
Vargas
Vargas
Use 220pF or 180pF any value from 100pF to 330pF is OK
Mr Mile, for HX 11
+/-35 for low and +/-63V for high rail voltage will be OK
Thank you for the quick answer mister Mile 🙂
Vargas
Vargas
I suggest to use 180pF it's look nice 🙂
Hello guys!
Yesterday I decide to use 180pF mica looks really good 😀 I'm going to order the transistors I need and some resistors that I don't have also the insulator for the TO-3 I don't have those, so yes I need them, the board on this pictures look a bit large than what it is but is ok on the second one I might just leave in that size it does not bother me at all well here are the last images then I have to wait for the part the get here in Puerto Rico good day guys 😀
Vargas
Vargas
- 100W Ultimate Fidelity Amplifier
