"crippled" f4 max psu voltage
hi all
i have gathered the parts for a f4 build using auto formers for my frontend and am going to be removing the jfets at the input (crippled as they say)
can i use a higher rail voltage now that the jfets are removed ?
i ask as i already have 2 potted 500va 25/0/25 toroids i,d like to use rather than buy new 18/0/18 toroids
i will also only be using 1x irfp240 /irfp9240 per channel instead of the 3x used with the normal f4 and would like to know if this is safe with the higher rails
cheers sheafer
