Op amp swapping
Joined 2004
I intend to mod two very old CD players hoping to get nicer results out of them:
1) NAD5425 (NE5532)
2) Sherwood CD1000C (jrc4560)
I have read about Op amp swapping by people the are modding their CD players. I have read that the lm4562 gives wonderful results.
However, I was wondering is it just out with the old, in with the new (of course considering that both amps have the same pinout) or does it also require some recalculating and redesigning with the new amp, and if so, how do i go about it ?
OPA2604ap
Thanks Mooly,
I have bought a batch of 10 OPA2604ap on Ebay just for the comparison.
I will fit sockets and compare as soon as I get both the 4562 and the 2604.
BTW, do you know what the 'AP' suffix mean, is the same as OPA2604? (I couldn't find any reference for the suffix in the datasheet...)
Again, thanks for everything.
Liquias.
Guys,
Thank you for the input and info.
I have ordered the LM4562 and the OPA2604, and I should receive it by mail in a matter of two weeks or so...
I plan on installing a socket into the print, so I can change between Op Amps and choose the one I like best. I'll be sure to update when I find which one I prefer.
Btw
When choosing a socket is there a preferred kind of socket?
I know two kinds I can use (pictures attached).
On the one hand the gold plated seems of higher quality, but on the other hand the contacts on the regular one seem to be better.
Which socket is best? Will I hear the difference ?
The larger "flat pin" is perhaps better if you do a lot of swapping.
The round hole type "damage" the pins on the IC slightly, but are better if the device is to be left in.
What I would also suggest is careful soldering of a small 0.1uf cap directly onto the IC itself across the power pins. If you do it carefully and neatly it will not effect the way it fits in the socket. If you do this clean the pins of the IC with ISO and a cotton bud before fitting in the socket to remove flux etc.
Will just add that personally although sockets have their uses, I don't like them and prefer to solder device direct in the PCB.
That said you will be fine with sockets, and no you won't hear any difference between them.
Thanks guys,
For everything.
I am now waiting for the new op amps to arrive. These things usually take time around here. I was wondering though, I read that a new op amp takes time to "Break-in".
I wanted to ask:
a) Is it true ?
and if it is:
b) How and when can I be sure if it happened already ?
c) How long does it usually take ?
a) If you believe it is. There's no actual evidence that this happens, no plausible reason that it even could happen, and the people who know more about these things than anyone (the designers and manufacturers) don't believe it happens, but if you believe, that's what you'll hear.
b) It will take as long as you believe it should take, deep in your heart of hearts.
c) It usually takes as long as the belief of the listener demands.
Qualifier: Some electrical parameters are temperature dependent and there *could* be some warm-up time changes, but that's distinct from "break-in," since it will happen every time you turn the device on.
It is curious that in the manufacturing process, the complete testing of an op-amp takes a second or less. To do so in this amount of time means that the op-amp must be meeting all specs at room temperature (or whatever test temperature, if not room temp) with virtually zero warm-up/break-in time. So, if this can be done practically in production, it's curious that somehow a device in an AUDIO product should take many orders of magnitude more time to 'break in'.
Feedback
Resurrecting, since I promised to post feedback from my tests. (And since I have some new questions...) 🙂
OK, so I bought LM4562 op amps and as Mooly recommended I also bought the OPA2604 op amps.
I finally had the time to conduct one of the tests.
I have only tested the Sherwood CD1000C player so far. It's easier since it has only one (dual) op amp at it's output.
So I switched between the jrc4560 op amp and the opa2604 amp. sound took a couple of steps for the better. everything is more emphasized and colorful. all the instruments got presence, and musicality. Voice became a couple of meters closer. I'm very happy !
Then I tried the LM4562. This is a strange one. At first what I could hear was a little less emphasis of everything (like the sound is a little less colorful) but a very large difference in detail. everything got "crisp" and clear. I liked this sound for the few first seconds.
But then I noticed I pickup a distinct distortion. It sounds like the twitter in my speaker has gone bad. (this gave me quite a scare BTW...) I tried decoupling the op amp with 0.1uF cap (between pins 4 and 8) and this doesn't change anything. sound is still distorted, I have no idea why, or how to solve this. Changing back to the opa2604 solves this problem of course.
Any ideas why the 4562 gives me this kind of trouble ? Am I doing something wrong ?
Thanks for reporting your findings back... I love the sound of the 2604.
As to the LM4562, well it's hard to say for sure but it certainly shouldn't distort in any way at all. A scope check would reveal what is happening but at a guess it may be verging on instability perhaps due to capacitive loading on the output pin. If you can try adding say 47 ohms in series directly from the outputs (pin 1 and 7) before they connect to the PCB to isolate the opamp. Worth a try.
CD player output stages usually can be improved by replacing the capacitors on the voltage rails. Using decent capacitors here can help with stability with faster op amps. It is usually possible to remove the DC blocking capacitor from the output stage and also remove the muting transistors for another improvement.
Thurther mods would really then involve upgrading the rest of the CD player. Again capacitor upgrades for the rest of the player are good.
You could look at some of the mods that others have tried to get a idea of what is possible.
One Website I found recently that was helpful
Ray's Audio Page
I modded a pair of old Marantz cd52 players last week using Elna caps for the analogue circuits, sanyo oscons for the digital, and some analogue devices op amps. The sound is more resolved than my stock Arcam CD72.(double the price!)
Time to upgrade that next😀
