Pair of Beyma 15XA38ND Pro Coaxial Woofers with Compression Tweeters. One Pair Only, like new, used for a few hours of testing. Woofers rated at 350 watts AES, 700w program; tweeters rated at 90 watts AES 180W program. Woofers 8 ohms, tweeters 16 ohms. Powerful lightweight neodymium magnets.
I tested these for use in the
Bitches Brew Live Edge Dipoles (link goes to forum thread here on DiyAudio) to cover the range 110Hz to 20KHz. I ended up choosing the B&C 15CXN88's instead, which are 2X as expensive, because the B&Cs have a more consistent directivity pattern than the Beymas from 4K to 7K.
For applications where you want a Coax (ie Tannoy concentric) these drivers are superb and also quite affordable. New units sell for a good bit more.
They can be used as a bass-mid in Open Baffle; with a good bit of EQ they could be used Open Baffle down to about 50Hz in a U-shaped configuration like you see
here; in a reflex or transmission line they will go down to 30Hz with 115dB+ output.
WOOFERS 15 inch, 98dB SPL, Fs 38Hz, 6.7 ohm DCR, Qms 6.4, Qes 0.31, Qts 0.30, Vas 238 liters, BL 20.4, Sd 880 cm^2, Xmax 6mm. 4 inch voice coil. See the manufacturer's data sheet for frequency response and impedance curves. Outside diameter 15.28 inches, cutout 13.85 inches.
I used these in a bi-ampified active system with MiniDSP digital crossovers. They sound absolutely fantastic. For my final design I opted for a B&C 15CNX88 driver with slightly wider dispersion pattern. The dynamic range is spectacular and the sonic texture is silky-smooth with a good crossover design.
The tweeters have an incisive, detailed and sharply focused timbre. If you want a tight sound radiation pattern with strong directional control, these are ideal. Perfect for creating Tannoy-style or Constant-Directivity Open Baffle (dipole) high-end monitors. Excellent for stage monitors and compact professional sound reinforcement speakers in churches and auditoriums.
$749 / pair plus shipping.
I only ship to the lower 48 states in the USA.
