Easy way to trigger 12VDC on subwoofer without receiver
Hi all:
I recently came across a Nakamichi Sound Space 12 sub and satellites. I want to test the sub to see if it works. However, it has a 12v DC jack on the rear to get it turn on, and I don't have a receiver or any other component with a 12V trigger jack function.
What's the easiest safe way to trigger that thing to turn on? I've read that you can't go beyond a certain current limit on a trigger circuit, or you could damage the components.
Let's assume I have extremely little understanding of electronics.
hello from Florida Yamaha B-2
hello all just acquired a yamaha b-2 no sound. i am trying to sell it as i dont have a tech near me i am including a 1000w step down transofmer i wish i could get it fixed but no knowledge nor techs in my area of florida. will ship. turns on. im in the florida panhandle area. looking to break even at $500 for all.
Lii Audio 15" full range
Proud owner here, as of last week. I threw them up onto a pair of table leg stands, just to be sure they're OK after shipping, as a Saturday morning effort. They are.
I'm quite happy with the sound. Now, I need to mount them on an OB design of some sort. Any assistance would be much appreciated!
I was casually thinking I might replicate Decware's "Betsy" design and would like to understand why the "barrel" shape works. Caintuck Audio, the originator of the Betsy, also offers "tombstone" style baffle boards with parallel sides.
Lucky for me, there's a Washington state surplus store very near to where I live, which has tables, desks and other MDF based bench-tops at very inexpensive prices. My plan is to pick something up and start cutting. If I'm lucky, there'll be two of something I could cut into a Betsy, or something with parallel sides I can simply trim to height.
The typical desk or workbench top laminate - my worry is how to get a clean edged, say, 16" circular cut in something that may be 2" thick. I like the standing mass of a baffle like that, but I dread trying to make such a cutout with something like a Sawzall. The Decware speaker mounting is flush with the baffle surface - looks really nice - However I assume the only way to do that is with a router...
Hopefully I'll be choosing a couple of hunks of material to work with this coming week. I could have got a pair of matching 6' diameter 2" thick tables - which would have easily yielded a pair of Decware style Betsy Baffles - for $5 each. I couldnt have lifted them atop my Subaru forrester if I wanted to. What practical width should I be setting my sights on for this 15" and its free air of ~50 Hz?
Thanks!
Reactions: Globulator
Modern Car Dashboards
In most of the new cars many of the displays and controls have been moved to a large touch screen and the traditional items removed. In the Telsa Cybertruck that has been taken to an extreme and except for a few things on the steering wheel everything has been moved to the large display. Here is a picture:
https://www.motortrend.com/reviews/2024-tesla-cybertruck-foundation-series-interior-review/photos/
Instead of being able to control things like heater, air conditioner, radio, etc., with a single button and motion you now have to first manipulate several steps on the touch screen to get to the item you want to change.
So are the new designs for the better, or do they in some way compromise safety?
changing from 8ohm (nominal) to 16ohm woofer [Altec 416] [LTspice]
Hi folks!
I am fooling around with Altec speakers, and trying to run the 808 8a + 511b horns with 416a / b style woofers. At the present time I do not have any questions regarding the HPF and horn correction circuit; I am hoping for some basic design input in the spirit of "look this direction".
At the encouragement of an engineer friend, I am learning to use LTspice. The following screenshot shows the Z19 / Altec Model 19 LPF. Top models use TS parameters associated with the 416Z (0.567 mH VC inductance / 11.6ohm series resistance) -- bottom models use the 416B (2.5mH / 6.5ohm series resistance).
In both screenshots, the bottom model represents the LPF circuit with the intended 8 ohm woofer. My intent is to create a model for a 16 ohm woofer which corresponds to the frequency filter response with the 8 ohm woofer.
First model, with matching crossover values:
With matching XO values, I get:
Top: 416 Z (16 ohm nominal): -6db @ 1.130 kHz
Bottom: 416 B (8 ohm nominal): -6db @ 1.330 kHz
With capacitor value doubled and inductor halved for the 16 ohm nominal speaker, I get this:
Top: 416 Z (16 ohm nominal): -6db @ 1.180 kHz
Bottom: 416 B (8 ohm nominal): -6db @ 1.330 kHz (unchanged)
I realize that I am a newbie and generally speaker crossovers are regarded as EXTREMELY complex, so I am not looking for a silver bullet. Does anyone have some math or anecdotal suggestions? What could I try next?
EDIT to add: I realize I am only using two parameters to define an inductor and there must be significantly more sophisticated ways to do this, and I'm learning as I go!
affordable calibration microphone
Hi everyone!
I am an audio enthusiast, and this last year I have been getting more and more into this world, specifically in box design. I don't have many tools to measure different things, such as the Thiele-Small parameters, which I was able to measure on my own with a circuit I made. But over time, I have realized that I need more tools to be able to reach the objectives I want, such as a calibration microphone. The problem is that I do not dedicate myself to this, nor do I plan to do so, at least not for the next few years, so I am not going to buy tools as expensive as a UMIK-1 or UMIK-2, or the Dayton Audio DATS V3 , since I don't have the ability to buy things at that price either.
My question is if there are cheaper options, specifically for the calibration microphone, I would like to have one. And if someone recommends other tools that could be useful to me, and that are not very expensive, I would appreciate it.
A Lateral MOSFET Power Amplifier Design Version 1.1
Hello,
Following Bonsai constructive comments and advises,
Ref.:
  1. https://www.diyaudio.com/community/...as-a-small-sizzling-sound.411503/post-7659500
  2. https://www.diyaudio.com/community/...as-a-small-sizzling-sound.411503/post-7660158
I redesigned my DIY Amplifier PCB. This is the same schematics as threads :
with the HBR resistor added, and a totally new traces strategy.
  • I removed all tests points except TP3, now renamed TP1
  • I moved the DC Servo closer to the IPS.
  • I made Rails connectors closer to each other.
  • The BIAS Spreader is closer to the VAS
  • I minimized the ground loop area at the IPS
  • I passed the +Rails and -Rails in folder view with their respective own ground traces under them, on the other side of the PCB
  • I kept the Signal ground return track close to the feedback track to minimize the possible ground loop, I also kept it without nothing connected to it.
  • I added the 4.7 Ohms HBR resistor, close to the input.
  • I put the speaker output at the very end of the traces.
I'd like to share the schematics and the new PCB captures for your comments. I am very open to any comments or advises from every ones...
My bests regards and, thanks in advance...
P.S.: Schematic attached below in PDF format.
01-Ground Components Side highlighted
02-Ground Solder Side highlighted
03-Rails Traces over respective grounds (grounds highlighted)
04-Ground Loop Area
05-Silkscreen on top
06-Silkscreen and Ground Loop Area
07-3D View-Top
08-3D View- Iso
Stability testing my new Rod Elliot P3A
Hi Guys,
I've built a P3A using Rod's boards, standard parts etc.
https://sound-au.com/project3a.htm
+/- 34Vdc rails
2SA1973/2SC5200 output transistors
KSA1220/KSC2690 drivers and Q4
BC546 Q1,2,3 and Q9.
The right channel is behaving normally.
The left channel isn't.
My dummy load is 4x 16R 100w resistors in parallel for 4.3R as per my DMM.
My scope is a Instrustar ISDS205B cheap and nasty USB jobbie.
My first test on the problematic left channel had 3Vrms on the output of the amp. After something like 30-60s the 3A fuses on the supply rails blew.
And the heatsink was pretty darn warm.
The 2nd test was going ok, same signal, same 3Vrms on the ouput, the supply rail fuses didnt blow. After probably 60s I saw a little puff of smoke come from somewhere around Q6/Q9. I didn't see any damage, I think it was the cable tie coupling q6 and q9 together beginning to melt.
After this I learned that I can only do short bursts of testing if I dont want to start replacing transistors.
I performed a few more short tests and took some screen shots to digest whats going on.
Right side 1kHz sine wave
Left side 1kHz sine wave.
Right side 1kHz square wave.
Left side 1kHz square wave.
There was also another square wave test on the left side that I did not get a screen shot of, that looked like this.
Forgive my crude MS Paint work. With my limited understanding this would be full scale oscillation.
This was a purely resistive 4R load, no capacitance in parallel.
So if I am not imagining things, I have a rather unstable amplifier that needs some love to get happy.
My first step is going to be to remove the board from the heatsink and give it a damn thorough eyeball to check for any mistakes, bad joints etc.
Assuming I don't find any construction errors, it seems to me that the next step would be to perform the same square wave test and do some probing around to see if I can find where the oscillation starts.
Putting switches/relays after the DAC output stage to select between combined outputs
I'm looking at building a DAC based around the 8-channel ES9039. One of the features to boost performance is combining the channels, which I would do after the output stage i.e. the op amps.
I'd like the flexibility of having all 8 channels, but there could be occasions where 4 channels would be enough, in which case I could make use of the unused channels by combining pairs of channels together.
Some of the ESS evaluation boards achieve this effect using headers and jumpers, but to be useful to me I'd want to be able to use a switch/relay of some sort. I am, however, cautious of adding anything in the way of the signal path. Would the performance improvement of combining channels be reduced by adding something like a relay to the signal path?
Delta Sigma Modulator by MarcelvdG
Hi all,
I made a separate PCB for the Delta Sigma Modulator by MarcelvdG shown in the
https://www.diyaudio.com/community/threads/valve-dac-from-linear-audio-volume-13.308860/
Thanks to Marcel for this project.
It is intended for Trenz TE0630 LX45 and LX75 FPGA modules.
This module is easy to program via USB and the Trenz application:
https://wiki.trenz-electronic.de/pages/viewpage.action?pageId=10620253
This module must be configured by shorting R102 pads on the FPGA board.
Actual LX45 configuration file see:
https://www.diyaudio.com/community/...r-audio-volume-13.308860/page-76#post-6569767
Actual LX75 configuration file see:
https://linearaudio.net/sites/linearaudio.net/files/additionaldatavalveDACversion2p1.zip
The FPGA code contains a sigma-delta modulator that has three modes selectable by switches.
Similarly, we can choose a filter.
You can read a lot of information about this modulator in the document:
https://linearaudio.net/sites/linearaudio.net/files/03 Didden LA V13 mvdg.pdf
Additionally, I included some information in the schematic.
This version has only I2S input/output.
I put schematic, boom and gerber files.
Hello
Hello world from Belgium.
I was graduated in digital technologies in 1982 and worked in Information Technologies. I'm now retired and as an audio enthusiast, i plan to discover the Tubes world.
My knowledge is only about transistors and Ic's ! I've made and repair some solid state amplifiers, mixers and speakers.
I subscribed a long time ago to find informations. Thank's to all
Greetings
ESI Impedance Bridge 250-DA
I have an ESI 250-DA Impedance Bridge for sale. Great condition and functions perfectly. I picked a different Impedance Bridge and do not need two. Has a newnpower cord and new 9V battery connector. Heavy, but will package well. See photos.
Asking $50.00.
PM if interested.
Amplifier peak power
I’m thinking of a 165w rms per channel amp for midbass. Mid bass specs narrowed down to either 100w rms to 200 peak or 120w to 170w peak. So pretty similar. Does an amp usually have more power? So 165rms means it can burst 200w no problem at all. Just wandering about a general rule of thumb might be when looking at amps. That a 165w rms amp channel can burst to 1.5x power no problem. So need to match amp rms to peak speaker handling. Thanks.
Mosconi Gladen One 120.4 no output
I been working for the past 2 days on this amp, I found 2 op amp circled with red in my photo that does not have power supply. It is in the front of the drive circuit. All op amps are all supplied except on these 2. If I can make it working then I believed output will.come. Furthermore because of its thick brown coating tracing backwards is very hard, for the traces are not visible. I did not find any diffective diode or parts either in the power supply section. Does anybody encountered this issue or does somebody can share an schematics diag , I will appreciate it much.
Newbie question about Power supply for Purifi Amp module
Hi all, I have a newbie question about the power supply for Purifi amp module.
I am thinking of building a linear power supply for the amp as I have a spare toroid transformer lying around (removed from a dead amp).
Now the issue is that the transformer has 4 x 50V (6A each) secondaries instead of 65V. Are there any issues with using 50V instead of 65V for the power supply?
Does anyone use a Macbook Air as a Digital Music Source?
After many years of using Windows laptops I intend to transition to a current model Macbook Air as my digital music source. I now play WAV files from my Windows laptop to a DAC then into an amplifier. I have a few questions for anyone with experience using a Macbook Air as a source:
1. If you play local files, what format do you use? I’m thinking about converting my WAV files to FLAC which would reduce my current total file size from 116gb to around or 70gb.
2. What music player app do you use for local files and streaming? I have used Foobar2000 and Jriver Media Center 31 & 32 and with Windows and have been happy with both. Just wondering if there are any other players for Mac OSX to consider.
3. Can the DAC/headphone out be set up to use as a DAC with line output? I have read elsewhere that the current Macbook have a very good DAC/headphone output. I’m just wondering if I could do away with a component here.
4. Does the Macbook have a Bluetooth output comparable to something like Aptx HD?
That is all I can think of for now, I may have more questions as comments come in. As always, thank you in advance for your advice!
Rick
Macbook Air
Making a bench variable constant current sink?
Beginner question for a schematic. I'd like to make a variable constant current sink so I can simply dial-in milliamp loads from 10mA to 100mA on the bench when testing power supplies for tube amps. I think in the industry they call this device an "active load" or something like that, anyway they are very expensive. In PSUD you can load your simulation with either a resistor or a CCS (in diagram below), that CCS (in yellow) is the thing I want to build for my bench. It should handle voltages from 90 to 450 volts and sink whatever current you select from 10mA to 200mA. I know I can simply use big resistors on the bench, but to land at the load you want you have to have that resistor on hand for the voltage you are targeting, then you have to do ohms law with all your spare big resistors you do have to get close to the mA you want. So I thought there must be a way to simply build a current sink where I can dial in (or rotary switch) to the amount of current I want to draw from the power supply under test. Can I simply do this with a MOSFET and a 500 ohm rheostat wired source to gate to self bias the FET as a CCS? Then make a paper vernier dial of the currents I can dial into, put it in a box and done. Or is this a bigger project? Has anyone built such a device here that will cover the voltages and amount of constant current I want to present to the PS DUT? Thx.
Measuring watts of a woofer
Estoy en un proyecto de un sistema de audio DIY con altavoces reutilizados, por lo que he tenido que medir todos los parámetros de los altavoces por mi cuenta, pero hay un parámetro que no he podido medir... Watts.
Los watts máximos que soportan mis woofers, y es un gran dato que necesito saber con qué fuente amplificar el sistema sin quemar mis woofers.
Entonces estoy buscando una manera de medir esto, por eso vine aquí, para ver si alguien me puede dar una respuesta o recomendación.
:cop: Moderation Edit. Please post in English.
I'm in a DIY audio system project with repurposed speakers, so I've had to measure all the speaker parameters on my own, but there's one parameter I haven't been able to measure... Watts.
The maximum watts my woofers support, and it's a big fact that I need to know which source to amplify the system with without burning out my woofers.
So I'm looking for a way to measure this, that's why I came here, to see if someone can give me an answer or recommendation.
psud2 simulation does not match measured and measured look weird? any ideas
Hello everyone,
I am making a trial 12V DC power supply with a transformer, and choke I already had and some salvaged capacitors from an old defunct project - so no investment apart from some diodes, really mostly for learning.
I have not yet got back my old 15V transformer that a friend is using so I found an old one wall wart 15v to start to understand and explore.
Well this is the current circuit I am 'comparing' simulation from measured
(for my real 12VDC I am going to build I will use the twin 0-15 transformer I have in series to give 30vAC I think to be able to get the noise down, according to simulations)
The current draw is 340mA Anyway this is the circuit and below is the measurements from an oscilloscope on DC and AC coupling.
The crazy thing is in actual measurement that last filter ADDS NOISE!! and the overall noise is way off e.. VC2 27mV predicted and 232mV measured?
Any thoughts?
VC1 17.1V DC and 5.3v p2p
VC2 13.5V DC and 232mV p2p
VC3 8.86V DC and 720mv p2p
How can I best tune room reflections?
I'm getting close to having my system dialed in, which brings me to the final frontier: tuning my room.
my listening room is in a smallish, 1500 sf condo and comprises my kitchen, living room and dining area. The room itself is about 16" x 24", the seating area where my system and sofa are is about 12w x 10" deep, with the dining area directly behind it and the kitchen to the left, as well as the main entry. I don't hear any prominent echoes when I clap my hands or snap my fingers, but the spectrogram tells a different story.
further complicating matters, the blank space above the credenza is a projector screen, so it can't be easily treated and the wall to the right is irregular and approximately 60-70% windows, with sheer curtains and blackout shades. how may I best treat my room to reduce reflections? my speakers, which resemble Klipsch LaScala, have passive radiators mounted on the back of the upper horn enclosures, extending the bass to 23Hz- intuitively, I'm thinking bass traps and diffusers behind and above the speakers and heavy rugs in front of the speakers; am I on the right track?
would mounting diffusers in the RH corner and above the L speaker, such as the one below, help?
iu
I could also install bass traps directly behind the speakers. Unfortunately, we rent, so treating the ceiling is not an option and WAF is also a consideration, as are budgetary constraints. That being said, what are the best bang for the buck options, assuming I have more than adequate woodworking skills (I'm a master carpenter and former cabinetmaker; I engineered and constructed my speakers and make my own furniture).
Audison HV Sedici
Amp powers up and idles at 20 amps of current .
Amp works besides the idle current is way to high .
Any ideas on this ? Do I need to adjust the bias or idle current ?
For Sale Coral mids and tweeters
A full set of 8 Ohm tweeters and 4 Ohm midrange from the Optimus range of speakers from Tandy/RadioShack from the 1970s.
Optimus were Tandy top of the line speakers, as most of you would know this combination was used in both the Optimus 5B and the Nova 8.
The Midrange are 4 Ohms and must be used in a series connection, this is the green wire
Complete with back cups and all the original wires with crimp connectors. Also included is the original polyester fibre damping material and as a bonus some long fibre reprocessed wool. Postage extra at cost
Speakers have been tested and all work. But they are vintage so I cannot guarantee them long term. Being small voice coils power handling is limited; especially if you use first order crossovers
Just listing for interests sake
Advertised elsewhere for $100- feel free to make me a more Realistic offer
Postage at cost only but pick-up in Geelong OK for forum members
Box will weigh 3 kilos with all the padding and packing
Just sold on eBay for the asking price
Class D T amp modules NEW
Brand new Sure Electronics Wondom class D and T amp modules. Never used.
2500 watt @2 ohm $150 for the pair
Two 2x150 modules $65each
Two 2x100 modules $50each
Shipping included in the usa. Will ship worldwide, contact me for details
Altec “Valencia” type cabinet
Hey everyone.
I’m the new proud owner of a nice NOS set of 806-8A, 811B horns, and 416-8A Altec’s. So now I need the Brain Trusts help in deciding on what cabinet to build for them.
I’d like to keep these in the 4-6cuft range and also would like to run the horns free air exposed sitting on top. So what would you guys do? Iconic style or Valencia with the horn on top?
As far as crossovers should I just grab a pair of the GPA N1200-8c and call it a day or is something else needed.
Amp power isn’t a problem from my Yamaha AS2200. I’ll also use digital room correction to extend and smooth out the frequency response.
Should I plan on adding super tweeters?
Basically if these showed up at your door what would you do?
Thanks.
TPA series: limit the voltage at the input pin
Hello, I need to limit the input signal voltage in my TPA313 amplifier within the range of 0V to 5V, and since the input has an offset of 2.5V, a 4.7V zener is perfect for cutting off signal peaks almost symmetrically beyond ~5V and ~-0.7V. In practice, it works, but the TPA seems to enter some kind of loop every 2 seconds: with no signal applied, it works correctly for 1s, the next second there is a snap, where the speaker membrane remains tense and still at its maximum height without any sound, including noise.
Where am I going wrong? Or alternatively to a zener, what could I use for the same purpose?
The zener is placed with the cathode to RIN+ and anode to GND. There is a 100R resistor between the input cap and the preamplifier.
Grazie.
FS: TOS 2SK2013/2SJ313
FS: TOS 2SK2013/2SJ313 and Renesas K1058/J162
I have for sale Toshiba 2SK2013/2SJ313. I ordered these from a supplier in Japan. They were made in late 2011, probably last production run by Toshiba.
Price is US$4.5 per pair (K2013/J313: 1 piece each)
Shipping is flat at $6 by registered airmail from Bangkok, Thailand.
Payment is by Paypal only.
Sorry, no matching service at this time.
Tony's latest traffo DIY build
this is a power traffo using a 2inch center leg stacked to 3 1/4 inch DEECO silicon steel (noss) irons..
specs are as follows:
primary: 220 volts 60hz.
secondary1: 250volts at 2amps.
secondary2: 100volts at 0.5amps
secondary3: 12.6volts at 10 amps
secondary5&6: 6.3 volts at 3 amps
completed, there are 3 chokes sitting on top, 1/2inch, 5/8 inch, aqnd 3/4 inch.
testing prior to dipping in polyuretahne varnish
line voltage:
magnetizing current:
unloaded core apparent power:
actual unloaded power in watts:
power factor:
Hi from Australia
Hi everyone,
I’m a new member but I’ve been lurking for a while just reading. I started out here wanting to do a wolverine build and ran short of time and the necessary equipment to get started (no bench power supply, scope died), so decided to start rebuilding an old NAD C372 to get into the groove of things and give me time to accumulate the right tools and improve my general knowledge, before tackling the wolverine in the near future… I’ve now got the bench supply on the way and was thinking about posting a rebuild thread for the NAD amp… hope to enjoy my time here and contribute something useful if possible. Thanks for the great forum!
Help ID Wu Gang Preamp please!
An old audiophile friend of mine, who is somewhat extreme in audio occultism lol loves to pot everything. Anyway let's not get into that(!).
I'm in the process of soaking this preamp he gave me in a chemical bath for a week or so. Just because I wanted it clean and ready for future projects.
The only way of reversing this potting solution mess is chemical baths followed by tiny holes drilled into the potted layer then a final soak in super glue remover for 78 hours.
Sadly some damage is inevitable, the odd snapped resistor or diode here and there.
My question is does anyone recognise this board? It has a Chinese phone number and "designed by Wu Gang" on the board. I want to find photos of the original board online so I can get a better idea of the component list (board scratches sigh...).
A schematic would be amazing however just some products photos would suffice.
I know this one is a real longshot but I would be extremely grateful for any help with this preamp.
There's some Muse caps here, it came pre-built from eBay (eBay I think), and with a blue potted/cased tranny on a small power supply board with single fuse holder.
Designing a solid state tube?
Schitt Audio has a preamp that is intriguing the FREYA+. It uses 4 6SN7 tubes. But here's the kicker... you can optionally purchase 4 "solid state" tubes. What are these? Well I assume they would have to be solid state circuits, in a bottle, with an octal base, that simulates the transfer function, curves, mu, rp, etc of a 6SN7 tube? So the circuit still thinks a tube is in the socket. Is this cool or what? Has anyone seen this concept used before with anything other than the old silicon rectifier substitute's?
Does anyone have a schematic of what solid state circuit might be fitted into an octal bottle to precisely impersonate a 6SN7? I'd really be interested in such a circuit that can be a plug in replacement of a tube, for study and interest.
https://www.schiit.com/products/freya-n
Reactions: gerrittube
WTB RCA MI-9449 Cones & Original Binding Posts for RCA Driver circa aprox. 1940~1950
Hey there everybody,
Curious who ended up with the stock of RCA MI-9449 cones that auctioned a few years back? They were selling in lots of 60 cones at 4.5k, I'm not that loaded so I just watched 'um sell... I need a pair - but if I can afford it would like to buy 4 or 5 pair and have a lifetime-ish supply. Idk what's a good offer, you tell me:
I'd also like to find a pair of this style of binding post, for restoring an RCA woofer which is missing them:
I would also like to identify any other manufacturers that used this piece of hardware, so if you recognize them & their cleanly-machined square slots, and would like to share the knowledge of the other possible sources (I.E. I'd like to part them out of a cheaper driver), I'd greatly appreciate that information... I could try to info-trade, I sourced a replacement basket from a cheaper driver as the donor...
Please excuse the cat hair visible in all three photos. The culprit:
Cat hair yes, but mouse poo, no. Everything in life is a balance of positives and negatives...
Reactions: OtisCampbell
DC 12V and 48V from a single 12V AC transformer winding
I am trying to make a power supply for a microphone preamp.
I have a transformer with a 12V AC winding and I would like to obtain 48V for phantom power and something around 12V to power relays, LEDs and a vu meter buffer.
The first approach I tried uses a voltage multiplier which produces effectively the desired 48V, and a bog standard 7812 section for the other rail.
The two circuits work well independently, but not if they are connected together to the same transformer winding.
It looks like the diodes in the multiplier and the ones in the bridge rectifier are interacting between each other creating some undesired current paths.
I have tried another circuit borrowed from a JLM power supply and in this case the two sections work well together (I guess it's because C1 and C2 provide isolation between the two rectifier sections) however despite the schematic claiming you can get 48V from a 15V AC transformer winding, my transformer which in fact outputs 14.5V AC (it's rated at 1A so the voltage is increased with no load) can only produce max 36V DC on the output.
I am looking for any suggestions on how to modify any of these two versions to meet my requirements, or by all means if you have an alternative circuit to suggest for this application.
Comparing P3A Schematics
So after my TDA7294 amp finally getting done with all the mods and options. I am now moving onto my P3A design. Full credit to Rod for his contribution to the DIY community.
So I purchased a few PCBs that are available to me in my country. Some are better than others. But all work.
My problem now is do I follow the values provided with these PCBs. Or do I follow the original design.
So far I have listed out the key areas of difference. I have then started to try each change one by one and see what sounds better and measures better.
But this is taking way too much time. Ideally I would like to just create a Simulation model. And keep changing values and seeing the results. Being new to Spice I can create the modell. But where I get lost is what parameters or commands would I need to monitor in the simulator.
If a spice expert could give me a starting point or list off commands to give spice.
I am attaching both schematics. The OG Rod vs the one I got with my local PCB.
In particular I'm curious about the value difference.
(When I first built this I kept blowing transistors. Then I had a lot of distortion).
All these problems were caused by fake components. The BD139 BD140 and main drivers were fake. One batch just failed. The other had a lot of distortion. No matter how bad the PCB is with the right components. This design just works.
The key areas where there is a huge difference in recommended values.
1. R3 / R39 = 470 ohms on Rods R6/R7=560 Ohms (I used 505.12 Ohms).
2. C2/C4 220uf/47uf on Rods C3/C5 100uf/100uf
3. R11/R12 = 220ohms on Rods R11/R12 100 ohms.
4. BC547 vs BC546 the implications. And I landed up using 2n2222 why because it sounded the best of all the ones I had on hand. Maybe psychological. lol.
There are a few other differences between the two schematics But I want to get to grips and understanding these 3 to start with.
If nobody responds. My backup plan is to just try both options measure noise and power output and just pick the one that sounds better to me. Im just curious were these values changed because they proved to work better or for some other reason.
HH MOSFET M900 DC offset 267mV when pot twisted to max?
i have set the bias on both Channels to 600mv
and set dc offset on Channel 1 to 0 mv
problem when offset stays at 267 mv when the trim pot is turned to maximum on Channel 2 ?
  • hh-electronic_m900.pdf
Totally agreed with Mr Ohashi
Mr Ohashi's Blog July 1, 2024​
Translated by Google translator...
Silent Majority​
July 1, 2024
It has long been said that a ramen shop that 5 out of 10 people think is delicious is a very successful shop. In other words, it is impossible for 10 out of 10 people to think that the ramen is delicious.
I happened to be talking to a colleague today, and he told me that he was very depressed after seeing some nasty comments online. In this day and age, it's said that everyone is a critic, and if you do an ego search on social media, you'll find a lot of nasty, negative comments, but personally, while I accept those opinions, I don't pay much attention to them.
The reason we have been able to continue this work for 26 years is because of the presence of the silent majority (the majority of people who do not like to speak up) who support us, and because of the trust and gratitude we have from our users.
For example, there may be some customers who say "I don't like the taste of this restaurant" at the register before leaving. However, worrying about that and losing your individuality is a bigger loss. You can just look forward, knowing that your restaurant can continue today because there are customers who come to your restaurant without you having to say anything because they "like the taste of this restaurant."
Just as other people's faces are different, the taste of ramen and the sound of audio equipment are also infinitely different. Since they are made by different people, there is no way that the taste (sound) will be the same. Moreover, with audio, multiple devices interact in complex ways to create the final sound, so even if the device you happened to choose doesn't produce the sound you like, we should understand that there are various factors and backgrounds behind this.
For example, a customer came to listen to the headphones today. He brought his beloved Marantz 7 original and McIntosh MC240 in the rain. Both are in very good condition and in perfect condition.
Using the 4344 listening room, the demo units SV-310 and SV-8800SE were used for comparison, and by changing the order and combination,
a total of four different sounds were enjoyed.
Even with the same combination of vacuum tube preamplifier + multi-electrode tube preamplifier, the sound output is completely different. With the
Marantz + MC240, the mid-bass region is emphasized, giving the sound a full-range sound with a large grain. With classical Tutti, the sound is a little rough, but it is very attractive in terms of density. With the Marantz + SV-8800SE, the high-frequency overtones are added, giving the sound a sense of spaciousness and fine grain, but depending on how you listen, you could even say that the Marantz feel has been diluted. The frequency response of the power amplifier is more than three times different, so the balance of the sound's dominance has changed significantly.
Next, with the SV-310 + MC240, the elasticity and bounciness of the low frequencies add to the dynamism of the music. If you don't mind a somewhat monochrome, sour sound, this may be the best combination for old jazz.
The last combination we listened to was the SV-310 + SV-8800SE, which many people actually use, and the customer said, "This is the best match." To put it in a positive way, you could say that the richness of the SV-310's sound and the flexibility of the SV-8800SE are well blended, but some people may find it too straightforward and uninteresting (sound source).
...As with anything, there are two sides to the same coin. Where there is light, there is always shadow, so it is only natural that evaluations will be completely opposite depending on where you focus and how you feel. Chefs and audio retailers like us do not follow recipes written in a recipe book, but rather believe in our own sensibilities and techniques, so I told them that there is no need to be overly confused by the rare loud minority (a minority that wants to loudly express negative opinions).
It's okay if there are people you don't like... but rather, please take care of the fans of your amplifiers, I felt like I was telling myself that today. We just have to quietly believe in the majority of people (=Silent Majority) who don't like to speak out and continue to make things honestly today... that's all we can do in the end.
For Sale Rare Toshiba JFETs available on eBay. 2SK389V , 2SJ109V , 2SJ109GR, 2SK170BL
I hope im not breaking any rules posting this here. But i wanted to let people know. I know fakes on Ebay are common but my seller feedback will confirm that i have genuine Toshiba parts.
https://www.ebay.com/sch/i.html?item=126478127702&rt=nc&_trksid=p4429486.m145687.l2562&_ssn=jsaarl
Edit: i made a mistake in the post title. 2389V should be 2sk389V. I also have some 2sk146V for sale
Hello from Milwaukee
I used to be an EE, then became a dentist, and as of last year, I'm retired. I used be do a lot of DIY and looking to get back into it.
Current system is older stuff- a TEAC VRDS-20 CD player, Squeezebox Touch, Krell KAV300i amp, SVS 3000 Micro sub, and Kanton Ergo 22 DC speakers.
I recently recapped the Canton speakers, and I'm 95% done with a recap of the Krell amp.
Blog page on the Kantons here: https://drmrehorst.blogspot.com/2024/06/another-recapping-project-canton-ergo.html
There will soon be a blog page on the Krell recap - waiting for a few more parts to come in.
SWTPC Stereo Tiger Repairs
I've been out of pocket for health reasons for a while but all good now. I finally got around to swapping out the resistors that were overheating in my stereo version and swapped out the PS caps with new mallorys.
The amp performs like a champ except for one thing that was also an issue with my universal tiger mono versions back in 1975, a faint 60 cycle buzz that can be heard in between tunes if preamp volume is at a relatively loud volume. Is there any grounding changes that could/should be made to the amp that might help in this respect? It's still got the original no-ground non-polarized cord cap but I'm assuming with the inputs and outputs being grounded to chassis that going to a earth grounded cord to chassis may not be advised?
Interlude Audio: New HiFi Brand doing both commercial and diy type products
Hi, I'm Ron, from Interlude Audio. We've recently launched an analog HAT for raspberry pi and we're about to launch our digital HAT. We plan on making more mainstream commercial products as well, like DACs and smart amplifiers. We like the diy space and are wanting to create for the diy audiophiles out there too.
Let me know if you're interested in our brand. I'll be posting info about our two HATs in the Vendor Bazaar.
For Sale PA150 LM3886 based on jeff rowland, now with all parts..
PA150 LM3886 pcb with all components to complete now with Jantzen input capacitor for sale:87€
IC's are new and are not applied on the pcb,like main capacitors,power connectors and SMD output resistors
the other components are already assembled, with genuine components,like on the second picture.
Machined Heatsink with the machined copper hardware and ceramic pads can be supplied the cost is 68€,
It is available for purchase in another listing.
DRV134 and gold plated pcb can be supplied if requested cost is 16€
I have also power supply pcb's for who want one model the power supply can be used for powers up to 400watt
and the other for powers up to 800watt, power supply partial assembled as example.
More than one set available
Tracked shipment to European union
Skematics sended together with articles.
If you are interested in this kind of stuff check here:
https://www.ebay.de/usr/dialedinmusic?_trksid=p4429486.m3561.l2559
For Sale Thank you diyAudio! I'm out of DIY … Parts inventory
Hi everyone,
Over the past 10 years I have learned much from DIYAUDIO.com and it's members. You have been great and I truly appreciate your support. Special call out to Frank, Andy, Bela, Alexander and the gentleman of hi-fi, Rod Coleman. Your support has been nothing short of great.
I am changing my life and as such, selling off my remaining DIY audio inventory. Hoping to find good homes for these products. All products come with a 5 day return policy (less shipping).
Here is what I have available. Let me know if you have questions or need photos. Accepting reasonable offers. Prices listed below, with the exception of the Muse Coil products (please email for pricing - banpuku@mac.com)
Thanks, Pat
Muse Coil Transformers and Chokes Minotaur Series (used unless otherwise noted)
2 x power transformer: 0-120-125Vac primary; 550-440-275-165-0-165-275-440-550 @ 50mA (10mA extra headroom). (please email for pricing - banpuku@mac.com)
2 x power transformer: 0-120-125Vac primary; 800-654-580-0-580-654-800 150mA & 130-0-0-130V secondary #2. (please email for pricing - banpuku@mac.com)
2 x L1 choke 30H 25mA 250Vac 23Rdc. (please email for pricing - banpuku@mac.com)
2 x L2 choke 16H 25mA 125Vac 27Rdc. (please email for pricing - banpuku@mac.com)
2 x L1 choke 12H 150mA 400Vac 25Rdc. (please email for pricing - banpuku@mac.com)
2 x L2 choke 7H 150mA 150Vac 23Rdc. (please email for pricing - banpuku@mac.com)
2 x Interstage Transformer 120H 30mA (new). (please email for pricing - banpuku@mac.com)
2 x Muse Coil OPTs: 9.1K - 4/9/16 ohm, OCC + OFC. (please email for pricing - banpuku@mac.com)
Input Transformers
2 x Finemet Input Transformers: SOLD
Slagle Intact Audio filament chokes
2 x 2.5A $90 / pair SOLD
2 x 3.5A. $90 / pair SOLD
Tubes (All NOS unless otherwise noted)
2 x Philips 814. $250 / pair
2 x GM70 graphite plate (100 hours). $200 / pair
1 x Heinz and Kaufman 25T. $75
2 x Eimac 35T. $100 / hapir
8 x 866A. $50 for the lot of 8
2 x EML 20B (200 hours). SOLD
1 x VT-51. $50
3 x Valvo Aa. $150 for all 3
Caps
2 x Duelund Silver/Copper Hybrid PIO 1.0uF. $180 / pair
3 x Russian PIO 50uF. $60 for all 3 SOLD
Many WIMA DC Link. too many to list, email for details
2 x Russian KY-40 0.22uF. $40 / pair
other various
Measurement equipment
Here is some different measurement equipment, only sale in eu cause of weight
Make an offer..
DC measured through series electrolytic capacitor
This must be a noob question but I will ask anyway:
I have an electrolytical capacitor coupled in series. The + side of the capacitor is connected to 6 Volts of a headphone amplifier circuit output.
With a multimeter I measure the other - side of the capacitor: I measure 6 Volts.
I expected to measure a few mV at most, theoretically 0 Volts. Is this normal behavior due to some voltage leakage and the high impedance of the multimeter?
Almost every capicitor I tried shows this. They cannot all be bad can they?
Looking for guide/kit for building a Bluetooth, 2.1 amplifier with display
I started out with this...
https://www.parts-express.com/2.1-A...ooth-LCD-Backlit-Screen-and-IR-Remote-320-636
And I am retro fitting it into the same cabinets as these... basically I am ripping out the original electronics, and upgraded the main speakers to these, https://www.parts-express.com/FaitalPRO-3FE22-3-Neodymium-Professional-Woofer-4-Ohm-294-1100
I got it all working and then started to create a new panel where I will add the display and my own buttons. However, the more I work with the kit, the more I dislike it. The display isn't very good. It's got the string "Music World" hard coded into it, and the bluetooth version is quite low (3.0).
So I started searching for a better solution, and I can't find one. What I am looking for is an amplifier kit with these specs...
  • Stereo channels
  • Subwoofer
  • Decent power (50W a channel into 4 ohm load?)
  • Highest quality bluetooth support
  • 2 AUX in
  • Decent display (i.e. something like https://www.adafruit.com/product/358)
  • Remote control
And I can't seem to find anything. So I started thinking... Could I build one? I have pretty good programing skills and have built many a project using ESP32 chips. I've also got good soldering skills and have a basic understanding of electronics. But I need help to fill in the many gaps I have. Do I use an ESP32 as the master controller? I found this (https://github.com/sle118/squeezelite-esp32) that shows the ESP32 is easily usable as an audio controller. But is this going to be high quality? Is it relatively easy to hook the 8-bit DAC built into the ESP32 to an amplifier circuit and will that be of any decent quality? I don't need thousand dollar HiFi, but I don't want poor quality either.
So looking for advice here... anyone want to work with me on this? I was thinking maybe a community project, open source the code and overall design and build it in a way that people could swap in their own amplifier specs or modify the code in creative ways.
Thoughts?
midrange horn design?
hi,
i just got my hands on four faitalPRO 12fh500 used for 350 euros.
my idea was to build four 15" tapped horns (JBELL SS15) and use my 12fh500 as midrange drivers.
i was wondering, is there any clever design i can do to increase the sensitivity of these? i am running an off grid setup on generators and want it efficient.
my SS15 will have a response curve like this:
some guy sent me this curve a couple of years ago that i saved:
i think he used four 8" car speakers in back of his car. the box looked something like this: https://en.toutlehautparleur.com/midrange-kit-tlhp-tt-112-with-cabinet-kit-and-speaker.html
i feel like that response curve would be perfect for my SS15 setup. is it something similar i can do with my 12fh500 drivers? 1000hz should be high enough to let compression drivers take over the job, right?
Cap Recommendations? Bryston BP-25
Hi Gents, wondering if anyone has some suggestions on a few nice caps for a Bryston BP-25 pre.
It's a lovely preamp! I've sourced the majority of filter caps etc from digikey, but across the signal path there are these 100uF 40v axial bipolar electrolytics. Stock ones are nice, German made, and wondering what I could use to refresh or even improve upon them while doing the rest of the caps.
They measure out 25mm long / 10mm in diameter.
I've been having a heck of a time..
100uF
40v or higher
Axial
Bipolar
25mm x 10mm dia - There is a little wiggle room on sizing / creative positioning but not huge unfortunately..
I was thinking Mundorf E-CAP RAWs. Any of the pros here have thoughts?
Happy new year!
EAR 869
I am selling a clone of the excellent tube amplifier EAR 869. It is characterized by a precise bass foundation with great dynamics/ tested with Sansui AU 111, with excellent results/. Power tubes are PL509 and ECC85 RFT, PCC88 Tesla. All tubes are unused. The input capacitor is from Mundorf. Power 15W in A class. Pl509 are connected Enhanced Triode Mode. Special connection of power tubes. The durability of PL509 is approx. 10,000 hours. Everything is installed in a chassis from Modushop. The 869 includes an input switch and a remote control. Spare tubes are included in the price/I will deliver later/. The price of the original is 7000 USD
Postage included in the EU price
Price 2100€
I need a DAC: PC>DAC>Krell>KEF
I am using a mini pc. crappy dongle DAC and have KRELL KST-100 amp and Kef 107/2 speakers.. I am looking to get a proper DAC, I have been checking youtube reviews for a while but none quite meet the requirements.
I don't care about Bluetooth, Wifi or ethernet streaming, I2S, HDMI ARC, I just want a DAC that supports MQA out of the PC via USB.
I like warmth, depth, airy sound, 3d sound stage, darkness in back, layers. Besides spending thousands on R2R DACs....I am not going that far. I also use TIDAL so I want MQA support....
I nearly just bought a SMSL D400PRO then watching iiWr reviews cancelled and bought D70 Pro Octo but then realized no MQA support, cancelled that too...he talked about it having large 3d stage, etc... but no MQA.
I was going to spend up to 1200~CAD if on amazon (AFFIRM monthly payments + return policy + free shipping). However if it's 500CAD great too.
From reviews, it seems ES chips are a no no--too digital/artificial and sharp/painful to listen to.
I do listen to jazz, guitar, but I also do listen to EDM/dance electro music. I like classic stage, opera, music too and even some old rock and jazz, soul, blues, whiskey blues, 50s, 60s and 80s pop.
So what do you guys run?
Visaton BG20 8" Full Range Driver Sealed Monitors
Hi all,
I've been wanting to play around with some full range drivers lately. No particular reason other than I have a couple pairs for projects and I have scrap plywood laying around. I like the sound of full range drivers and I love the simplicity of using them for simple applications where I don't have to get into crossovers and can simply integrate with subwoofers and have a full range system. Anyhow, I have a pair of Visaton BG20's (8" full range drivers, typically good from 40hz to 18khz) that are about $40 a piece and was going to do an open baffle with them but then decided I wanted to play with some monitors or bookshelf class cabinets. I toyed between bass reflex, tapered horn and sealed and ultimately I opted to go sealed and limit them to a small enclosure volume as they would be integrated with a sub so I didn't need to push extension. Cabinet shape, I went with an almost cube and I found that with 0.5 ft^3 they would roll off after about 80~100hz which was about my goal for simple integration with subs, F3 was closer to 82hz if I recall when I modeled. I measured later to see what it was.
Applications: Stereo listening, heights, atmos.
I'm currently listening to them in a stereo field on a simple setup with a sub integrated and just listening to my typical music. My first impressions are positive. I had no expectations for these but ultimately I find them to present vocals naturally and dialog in general quite nicely. They do exhibit some beaming in terms of dispersion, expected of an 8 inch driver like this, however from just listening and moving along angles I found it to be pleasing and acceptable to listen to up to 15 degrees off central axis in total, or 30 degrees total dispersion centered on axis and still felt like it was a good listen and the treble didn't die off. After 15 degrees it definitely falls off rapidly, so not good for wide dispersion needs, but totally good for applications that have the seating within 30 degrees of central axis, at least, to my ear. I may measure later to see what it's doing. But it wasn't mission critical.
Long term I think I will be using these for height channels and/or atmos channels. They don't need a lot of range. They're not mission critical for output and are really just for ambient effect. They came out to about 12lbs each, so they're not too heavy and can mount on the walls easily with some metal mounts that articulate. But I will do that later. For now, I'm just listening to them in a stereo setup with music and a sub.
Finished cabinets with drivers:
Cutting, Assembly and Finish:
Some 3/4th inch thick birch veneer plywood (4x4 feet scrap)
Wen track saw with track
Assembly is just wood glue (Titebond) and clamps. I had just enough clamps to do both cabinets at the same time. I need more clamps!
Home made jig and measured with the hand router and an up cutting spiral bit for making the driver holes.
Calked all the insides at all joints.
Terminals pushed through some drilled holes.
Finishing:
A coat of Minwax Natural
Next, a coat of satin poly
Wiring, Gasket, Stuffing, Driver Installation
I made some basic cables with spades and hoop terminals.
Hot glued them after installing just to give them another level of "stay put."
Same thing on the hoops internally on the terminals, threaded down some washers and nuts and then got glued them to keep from vibrating loose.
Very best,
4- vs. 8-Ohm woofers for this design
I’m planning for a new project of 2.5 ways triple woofers floor-standing loudspeakers. I wonder whether I should use 4 or 8 Ohms driver for mid & woofers.
There’re two options I could figure out:
I) Using 8 Ohms drivers
Speaker A will be 8 Ohms
Speaker B will be 4 Ohms, formed by two 8 Ohms connected together in parallel
II) Using 4 Ohms drivers
Speaker A will be 4 Ohms
Speaker B will be 8 Ohms, formed by two 4 Ohms connected together in series
Transformers and frequency response extremes?
Help me understand something about the output transformers in our tube amplifiers please. The response of most output transformers seem to look like this in general, with some degree of rolloff at both frequency extremes, especially below about 40Hz.
So how do we get anything resembling truly flat frequency response when the transformer sags at both extremes like this? Is the answer that negative feedback in the amplifier corrects the tansformers' frequency rolloffs at the extremes?
Another question: the inductance of a transformer controls the low frequency roll off, correct? I found this formula:
L = Z / ( 2π × f)
where Z is source impedance and f is the -3dB frequency
example: L = 6000 Ohm primary impedance/(2π × 40 Hz) = 24 Henrys is the required inductance for response to be down 3dB at 40Hz
Did I get that correct? If so, and we start looking at a situation like -1dB at 20Hz, we end up with huge values.
How do we calculate the -1dB point instead of the -3dB point? I am mathematically challenged and always have been. 😉
And as if that were not enough, let's throw in any differences for single-ended vs. push-pull transformer response and roll off calculations.
Sometimes I think it's a miracle that any of these amplifiers make sound at all! 😵
Reactions: anchorman
Altec 604-8H
I think these deserved their own thread. I want to share with our community.
Tested, and in good condition. Flaws are minor.
XO's have been recapped before I got them, meaning these are not NOS obviously.
Local pick up only. These babies should not be shipped.
Please come to North Surrey to listen before considering buying.
$1,500 CAD for the pair. Or $1,100 USD.
BTW, bring beer. I will have sandwiches. I also have a shipload of other things you might like.
Tannoy Autograph Cabinet?
Hello!
I recently helping my friend to seek a cabinet for Tannoy Autograph.
Whether the attached drawings are good for building such a cabinet?
Please inform if any mistake from the drawings before submitting to the cabinet maker 😁
Thanks 😊
Weller WP35 Soldering Iron
Found this in my old basement workshop and thought I would see if someone here might like to own one of these. The Weller WP35 is described as... "Weller® Professional Soldering, 3-wire Cord, 35W, 120V" No separate power source, just plug it in and go. It has a good sized "screwdriver" style tip in very good condition. I cleaned the oxidation from the tip and heater bore with a wire brush, allowed it to warm up and did some soldering, works great! How about $SOLD plus another $10 for shipping in the US. I will include both stands shown in the pictures and you can use whatever you want. A good choice for maybe someone just starting out that wants good quality but not quite ready to spend big bucks on a fancy pants soldering station. Thanks for looking.
Speaker replacement
I've got a pair of Automatic Radio bookshelf speakers that I recently modded with a Foster tweeter from a pair of Zenith Allegro speakers.
The problem is the doped cloth surrounds. The dope has hardened and nothing I have tried within reason will remove it and only softens the dope up for a few months.
The box before swapping tweeters. This is a photo of the 4 ohm version, but the ones I modded were the 8 ohm version. Same cabinet same size drivers just different ohms.
If it is not possible to remove the dope without destroying the speaker I will need an 8 ohm speaker that is exactly 5" in diameter with a bolt circle diameter of 4 3/4" that can handle at least 20 watts and can be rear mounted on a baffle. So far in a casual search, most 5" speakers I've found are larger than 5" or have a bolt circle diameter of greater than 4 3/4". Response should be from about 70Hz to around 3.5kHz. I can get a more exact number tomorrow.
What sort of reasonably priced speakers under $50 are available?
I am looking at a set of Klipsch speakers, however I most likely will not be able to get those until later this year or possibly next year and need something in the mean time.
Can anyone here modify my Marantz HD DAC1 headphone amp?
Hello, I have two Marantz HD DAC1 headphone amps.
so I thought to mod the one.
the headphone part has distortion and is a shame I was thinking to go to waste since it has a super nice alps motorized pot and nice components.
Is anyone skilled enough to mod the headphone part for me and make the headphone amplifier sound clear without distortion?
the schematics are readily available online
https://www.manualslib.com/manual/2859921/Marantz-Hd-Dac1.html
thanks in advance
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,646
Members
7,882,612
Messages
Filter
Forum Statistics
Threads
405,961
Messages
7,882,612
Members
507,646
Latest member
joveaaron
