About heater regulated supply
I wonder if someone have experienced a ULN-HC78A as regulation element in a heater PSU.
ULN-HC78A Ultra Low Noise Positive Regulator 2.5V~30V Output High Current Type | eBay
Does it perform as it costs???
Thanks in advance.
Victor
Victor, many commonly used preamp tubes operate at either "6" or "12" V. Building a 12 V. regulated supply is very easy. "Full wave" voltage double 6.3 VAC, using 2X Schottky diodes into a large valued cap. stack. Follow the rectifier setup with a 7812 3 terminal regulator. The AC RMS current capability of the filament trafo should be 4X the 12 VDC draw.
Hi Victor ,
You do not need to spend USD$ 59.00 (!!!!) to have good regulation and low ripple in a simple "heater voltage regulator" !!! It's a waste of money !!! Use the simple , easy do find and cheap LM317T voltage regulator !!! The circuit use only two resistors , one capacitor and two diodes !!! The circuit is on the manufacturer's datasheet , and you will find it here : Datasheet4U.com - 900,000+ datasheet pdf search and download
LM317 does not always work, same with LM337. Cold heater inrush current activate overload protection. Not with all tubes, but with some it will happen.
I always thought that well filtered heater supply is better than simple AC. Yes it is more simple with AC and it quite works well with a separate heater in a tube bulb. It also depends on an amplifier topology of course, a hard driven tube can add an intermodulation products etc.
LM317 does not always work, same with LM337. Cold heater inrush current activate overload protection..........
I'm sorry to say that Mindutis , BUT you are completely wrong !!! If you operate the LM317T within their current limits (with conservative values) may be 0,7 Ampére (+/-) at nominal tube heater voltage and nominal tube current demand , the overload protection WILL NOT act !!!! If the current demand is bigger than that you can use 2 separate pcs of LM317T , you will save a lot of money and get a very fiable source of heater voltage !!! ALL of my preamplifiers ( I made them to sell) use this system and NEVER had any kind of problem !!!! Listen to my experience !!! It will work fine !! OK ???;)
Half the price, and almost twice the current:
The Micrel / Microchip MIC29752WWT regulator linked to in this post is "not recommended for designs" on page 3 of it's own data sheet.
The TO220 versions, one of which is good for 5 amps are not on the endangered species list. I can confirm that one MIC29502 will run a pair of 2A3's with a dropout voltage of about half a volt. The large heat sink to the left of the 2A3's is for the regulator and the smaller heat sink is for the dual Schotkey diode that provides FWCT rectification from a 6.3V CT winding. I haven't tested to see if there is enough headroom for 6.3 volt filaments from 6.3V feeding a FWB yet, since it's not necessary in my application.
