You have no items in your cart.
Currency
Search results for 'amplifier'
6 Item(s)
per page
Grid  List
Set Ascending Direction
  • Front
    Deluxe 5U "Big Amp Chassis" (All Aluminum) V2
    $399.00
    Sold out!
    Warehouse Location USA
    Height 5U
    Heatsinks 40mm Wave Profile
    Top Cover 3mm Aluminum (Maximum Vents)
    Bottom Cover 3mm Aluminum (Maximum Vents)
    Front Panel 10mm Silver Anodized Aluminum
    Rear Panel 3mm Aluminum
    Interior Dimensions Internal width: 360mm, Internal height: 210 mm
    Exterior Dimensions Width: 450mm, Depth: 400mm
    Extras Front panel pre-drilled and tapped, Heatsinks pre-drilled and tapped, Maximally vented covers, Perforated base included, Rear panel pre-drilled and tapped
  • F-6 Kit (PCB+Jensen Transformers)
    $119.00
    Sold out!
  • Showing back panel kit installed (not included)
    Deluxe 4U "Jack of all Chassis" (All Aluminum) V2
    $329.00
    Height 4U
    Heatsinks 40mm Standard Profile
    Interior Dimensions Internal width: 360mm, Internal height: 165 mm
    Exterior Dimensions Width: 450mm, Depth: 300mm
  • matched jfets (2 pairs, grade B)
    Matched JFET pairs (Grade B)
    $34.95
    Sold out!
6 Item(s)
per page
Grid  List
