You have no items in your cart.
Currency
Full width with 40mm Heatsinks
All these chassis have 450mm faceplates and 40mm heatsinks.
4 Item(s)
per page
Grid  List
Set Descending Direction
  1. Showing back panel kit installed (not included)
    Deluxe 4U "Jack of all Chassis" (All Aluminum) V2
    $329.00
    Sold out!
    The perfect DIY amplifier playground!  Loaded with features designed specifically to make the life of a DIY amplifier builder easier.  No drilling!  No tapping! Any questions just ask here. Now upgraded and with new features!
    Learn More
    Height 4U
    Heatsinks 40mm Standard Profile
    Top Cover 3mm Aluminum (Maximum Vents)
    Bottom Cover 3mm Aluminum (Maximum Vents)
    Front Panel 10mm Silver Anodized Aluminum
    Rear Panel 3mm Aluminum
    Interior Dimensions Internal width: 360mm, Internal height: 165 mm
    Exterior Dimensions Width: 450mm, Depth: 300mm
    Extras Front panel pre-drilled and tapped, Heatsinks pre-drilled and tapped, Maximally vented covers, Perforated base included, Rear panel pre-drilled and tapped
  2. Front
    Deluxe 5U "Big Amp Chassis" (All Aluminum) V2
    $399.00
    Sold out!
    This is the big one!  We call it the "BIG Amp Chassis" for a reason.  It's huge!  And it's loaded with features designed specifically to make the life of a DIY amplifier builder easier.  No drilling!  No tapping!  Any questions just ask here. Now upgraded and with new features!
    Learn More
    Height 5U
    Heatsinks 40mm Wave Profile
    Interior Dimensions Internal width: 360mm, Internal height: 210 mm
    Exterior Dimensions Width: 450mm, Depth: 400mm
  3. Standard 4U Amplifier Chassis (Mixed steel and aluminum)
    $229.00
    Sold out!
    This is a no frills version of the "Jack of all Chassis", suitable for people who can drill and tap their own heatsinks, as well as cut the rear steel panel for connectors.
    It features steel top/bottom covers and back plate, aluminum heatsinks and 10mm aluminum faceplate.  It has maximally vented top and bottom covers, to allow the maximum possible internal airflow for class A amplification projects.
    Learn More
    Height 4U
    Top Cover 1.5mm Steel (Maximum Vents)
    Bottom Cover 1.5mm Steel (Maximum Vents)
    Rear Panel 1.5mm Steel
    Extras Maximally vented covers
  4. Standard 5U Amplifier Chassis (Mixed steel and aluminum)
    $299.00
    This is a no frills version of the "BIG Amp Chassis", suitable for people who can drill and tap their own heatsinks, as well as cut the rear steel panel for connectors.
    Learn More
    Height 5U
4 Item(s)
per page
Grid  List
