You have no items in your cart.
Currency
Full width with 40mm Heatsinks
All these chassis have 450mm faceplates and 40mm heatsinks.
4 Item(s)
per page
Grid  List
Set Ascending Direction
  • Standard 5U Amplifier Chassis (Mixed steel and aluminum)
    $299.00
    Height 5U
    Heatsinks 40mm Wave Profile
    Top Cover 1.5mm Steel (Maximum Vents)
    Bottom Cover 1.5mm Steel (Maximum Vents)
    Front Panel 10mm Silver Anodized Aluminum
    Rear Panel 1.5mm Steel
    Interior Dimensions Internal width: 360mm, Internal height: 210 mm
    Exterior Dimensions Width: 450mm, Depth: 400mm
    Extras Maximally vented covers
  • Standard 4U Amplifier Chassis (Mixed steel and aluminum)
    $229.00
    Sold out!
    Height 4U
    Heatsinks 40mm Standard Profile
    Interior Dimensions Internal width: 360mm, Internal height: 165 mm
    Exterior Dimensions Width: 450mm, Depth: 300mm
  • Showing back panel kit installed (not included)
    Deluxe 4U "Jack of all Chassis" (All Aluminum) V2
    $329.00
    Height 4U
    Top Cover 3mm Aluminum (Maximum Vents)
    Bottom Cover 3mm Aluminum (Maximum Vents)
    Rear Panel 3mm Aluminum
    Extras Front panel pre-drilled and tapped, Heatsinks pre-drilled and tapped, Maximally vented covers, Perforated base included, Rear panel pre-drilled and tapped
  • Front
    Deluxe 5U "Big Amp Chassis" (All Aluminum) V2
    $399.00
    Sold out!
    Height 5U
4 Item(s)
per page
Grid  List
