Go Back   Home > Forums > > >
Wild Burro Audio DIY full range speakers from Wild Burro Audio Labs
Old 5th November 2013, 06:45 PM   #1
cervelorider is offline cervelorider  United States
cervelorider's Avatar
Default 1939 Zenith Radio Burro Betsy
A non-audiophile friend of mine requested I convert his non-functioning 1939 Zenith radio into a working stereo that he and his kids could use with their iPhones and iPods in their 1920's home. His criteria was that I keep the project as low cost as possible (read no restoration parts), while still coming up with some decent sound. I gutted the tube amplifier/tuner parts and replaced them with a 15 watt per channel TPA3122d2 Class D amplifier. This amp can run successfully off a safe, 12 volts. The TPA3122 is also a good match sonically to the Wild Burro drivers. The original baffle board was removed and a new one constructed from Birch ply. Two Betsy drivers were installed on the new baffle board. This thing rocks! As anyone knows, two Betsy's can go quite loud with 15 watts.
Old 5th November 2013, 09:24 PM   #2
R.I.P.
An inductor (possibly with a parallel resistor) on the bottom unit might
be useful to make it richer and reduce vertical comb filtering effects.
We are talking cheap tweaking and voicing here, not rocket science.
Very nice cabinet though. I wonder if the central sections were
intended to have any acoustical purpose, I suspect perhaps.
Presumably its mono.
rgds, sreten.
Old 6th November 2013, 11:32 AM   #3
In 1939 it was mono of course. Now it's stereo.
rgds, sreten.
Old 6th November 2013, 01:07 PM   #4
ejfud is offline ejfud  United States
ejfud's Avatar
Pretty cool. Nice work.
Gary
One good driver is all I need.
Old 7th November 2013, 06:53 PM   #5
d to the g is offline d to the g  United States
d to the g's Avatar
Neat!
Old 7th November 2013, 08:43 PM   #6
R.I.P.
You have wired the drivers vertically in stereo ?
Not the best plan IMO, but it will work in a fashion.
rgds, sreten.
Old 11th November 2013, 06:51 PM   #7
What's the best plan Sreten? I'm open to suggestions for the next one.
rgds, sreten.
Old 26th September 2014, 02:48 PM   #8
Squeak is offline Squeak  Denmark
Squeak's Avatar
I think you did really well actually. The wood beams in front of the grill will work as a diffuser but then you will also need all the treble you can get. So no inductor or anything on any of the drivers.
The stereo difference will cut down on interference in the high frequencies anyway.
A bit of furniture polish and/or bees wax on that beautiful old cabinet could do wonders though.
Sad to hear that all of the old 1920s electronics had to be gutted. You might as well have left it in and just put the amp in a safe place. Looks as though someone had been there before with all the modern components strewn around though.
Old 11th October 2014, 03:08 AM   #9
hectori is offline hectori  Chile
Next one??? Please stop killing those amazing Old Radios... keep original, and use your electronics knowledge for RESTORE a beautifull chassis with the original tubes please.... Use the DIY for make DIY things...
Sorry, im a radio collector...
Old 12th December 2014, 12:56 AM   #10
Oh please. Do you know how many of these go to the junk yard? I saved it from there. Do you know how expensive it is to restore one? Do you know how difficult it is to find someone that has the knowledge to do a restoration. Do you know how many people still listen to AM radio? Be happy that someone is listening to this gem everyday. Two of which are teenagers, playing modern music through a 1930's look chassis that fills the house with sound. Sorry, but you stated your opinion and I'm stating mine.
I'm not killing anything, I'm breathing new life into it with new a new heart.
1939 Zenith Radio Burro BetsyHide this!Advertise here!
Wild Burro Betsy OB Build danvprod Full Range 50 30th January 2015 07:04 PM
FS: Wild Burro Betsy sideways Swap Meet 10 26th October 2013 02:18 PM
FS: Wild Burro Betsy Loudspeakers danvprod Swap Meet 2 6th August 2013 08:34 PM
Visaton B200 Vs. Wild Burro Betsy... Manolo47 Full Range 11 3rd April 2013 08:11 PM
Wild Burro Betsy with Plugs. bigaudioscotto Full Range 5 10th October 2011 09:16 PM
