Go Back   Home > Forums > Commercial Sector > Manufacturers > Wild Burro Audio
Wild Burro Audio DIY full range speakers from Wild Burro Audio Labs
Old 12th December 2012, 09:31 PM   #21
nicoch58's Avatar
fastbike1 you certainly seems not to be aware how OB work....
Sic58
Old 15th December 2012, 12:13 AM   #22
cervelorider's Avatar
Fastbike: Don't take the criticism personally. Every diy project is met with skepticism by some. If these sounded like Donkey dung, I would have documented such. However, as many "rules" as these break, they sound magical to the five sets of audiophile ears that have now heard them.
Old 16th December 2012, 03:42 PM   #23
Trust me, it doesn't bother me, particularly when the commenter "seems to not be aware" of the point of my comment.
You have clearly understood the point. To often folks forget about the music. My personal thought is that if the speakers can't make you forget about "critical listening" and draw you into the music, they're not "working".
I was so much older then, I'm younger than that now.
Old 16th December 2012, 03:48 PM   #24
nicoch58's Avatar
I 'm here to learning and evolve not just to show !
Sic58
Old 16th December 2012, 04:52 PM   #25
nesha is online now nesha  Serbia
Let's be constuctive... Fasbike, you can use the EDGE calculator to check the efects of offset-mounting drivers on baffles, and how lifting them off the floor affects the bass response.
Old 16th December 2012, 06:23 PM   #26
I agree. Definitely run the numbers. EDGE is a useful tool.
And to Nicoch58: Since you indicated you are here to learn, which I intrepret as a solicitation for expanding your knowledge concerning all things open baffle, I will give the following advice:
What I have found "constructive", and the greatest way to learn about real life baffle acoustics, is by building test baffles. It's about the simplest diy audio project one can tackle. Since the room size, room acoustics and placement of the baffle within the room play a MAJOR role in the sonics of an open baffle, make a few of various sizes out of the cheapest sheet goods you can find.
Saw them in various different shapes, sizes and cut your holes, varying offset to test that too. You can even cut them in the center to start, then cover up the center hole and put one off center, covering the other with thin wood stock. Then, use cinder blocks, a chair, dumbells, small children, etc. to prop them up.
Try them in various places in your listening room. Then, another room in the house. Close to the back wall, far away, different listening positions, close together, close to the side walls, etc. This is good, constructive learning in addition to using Edge. I guarantee you'll have learned a lot about open baffles after doing this.
Old 16th December 2012, 06:35 PM   #27
nicoch58's Avatar
Thanks is only 30years that I build speakers.
Sic58
Old 16th December 2012, 07:37 PM   #28
Sorry if my suggestions offended you. Perhaps they will be useful to a younger, new to the hobby audiophile.
Old 17th December 2012, 08:50 AM   #29
nicoch58's Avatar
Well no problem
Sic58
Old 17th December 2012, 11:34 AM   #30
Urchinn is offline Urchinn  United States
So these are a 38" square, lifted 18" off the ground? Those legs look shorter than 18" to me. And there is no baffle correction of any kind? I am going to try to make these...but I just want the dimensions correct!
Hello from Hong Kong! griffiths Introductions 3 1st August 2012 08:54 PM
Hong Kong Inventory mobyd Everything Else 1 25th October 2010 04:08 PM
Anywhere in Hong Kong... nickds1 Tubes / Valves 25 23rd September 2007 01:15 PM
Hello from Hong Kong. martinlo Introductions 9 20th April 2005 12:30 PM
Hello from Hong Kong Brian Cherry Introductions 5 5th June 2002 03:06 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
