Go Back   Home > Forums > > >
Wild Burro Audio DIY full range speakers from Wild Burro Audio Labs
Old 26th December 2012, 04:47 PM   #21
Randy in Caintuck is offline Randy in Caintuck  United States
Randy in Caintuck's Avatar
Originally Posted by cervelorider View Post
I don't know Randy, I've run all kinds of calculations through all kinds of programs and have found there is no possible way those could sound any good at all.
Hey buddy,
That must be my problem ..... I have this bad habit of relying on what my "lying ears" are telling me ......
Thanks for the info on the BetsyK ..... I still may give them a whirl when I get time.
I think Rob hit it smack on the head when he told me that driver height means everything when it comes to the Betsy drivers ..... when everything is right, they punch way above their weight class.
I'm still keeping a spare pair of Betsy drivers to do a set of Donkey Kong baffles ..... so many speakers to build ..... so little time .....
Hoping to see you in January,
Randy
Old 26th December 2012, 05:01 PM   #22
BTW ..... the final speakers will hopefully end up being a variation on the theme of these extremely fine looking beauties that were posted on the Hawthorne Audio forum .....
If they turn out half as well I will be a happy camper .....
Randy
Old 27th December 2012, 12:58 PM   #23
GM is offline GM  United States
GM's Avatar
Definitely nice looking, but like nearly all consumer OB designs, hence DIYer's, way too diffractive for me.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 28th December 2012, 01:33 PM   #24
GM
Hi GM,
Do you have an example of a "consumer OB designs, hence DIYer's" speaker that is not "too diffractive" ? You have me curious .....
Also, what speakers are you currently using in your system ?
Thanks,
Randy
Old 28th December 2012, 01:48 PM   #25
I started a new thread for the project mentioned above .....
Enjoy,
Randy
Old 28th December 2012, 03:14 PM   #26
GM's Avatar
Happy New Year and all that jive!
Pick one, since virtually all wide BW OBs I've seen are acoustically too small based on the driver's specs once all losses are accounted for and/or based on the XO point/slope nor do they provide some means of damping reflections back to its 'throat', same as needs to be done with a truncated horn.
After all, what is a horn but a folded up OB, so the need for proper size, termination, etc. required for accurate reproduction magically becomes irrelevant once flattened out? Not in my understanding of sound propagation.
I currently have no functioning system other than the one in an old RPTV, though my main system has always been horn loaded from at least 500 Hz since age 14 and for most of the time down to ~40 Hz [corner loaded 70 Hz expo compression horns].
That system plus a pair of Servo-Drive Contrass sub kits along with most of my good electronics went the way of a forced 'fire sale' over a decade ago now, so my main speaker system option has been limited to a pair of ~stock Altec 511 horns perched on top of my original ~20 ft^3 dual Altec 515B/channel 'subs', neither of which is optimized for wide BW use beyond PA/DJ apps and for a variety of reasons have been non-functioning for much of this time, though not for lack of some folk's generous efforts.
GM
Old 29th December 2012, 09:17 AM   #27
nicoch58 is offline nicoch58  Europe
And regarding the Betsy K vs. Betsy. I have both and the Betsy K does definitely sound "different". It is more precise throughout the entire frequency band, but at the same time, is not as forgiving of poor system matching or hot recordings. The Betsy is more laid back.
Nice to know ... what amp you used ?
Old 29th December 2012, 12:08 PM   #28
cervelorider is offline cervelorider  United States
cervelorider's Avatar
DIY TPA 3110, 3122 and TDA 2616. I've heard the Betsy with SE el84 amp as well.
Betsy drivers are REALLY goodHide this!Advertise here!
For Sale: Wild Burro Betsy Drivers - Pair norman bates Swap Meet 3 13th October 2012 09:18 AM
For Sale: Wild Burro Betsy-K Drivers - Pair Karl71 Swap Meet 2 18th September 2012 06:11 PM
What are good 8" drivers for a 2-way? stephenmarklay Multi-Way 83 28th November 2011 01:11 PM
Surprisingly good "amplifier" for Betsy K roger_lew Wild Burro Audio 6 11th July 2010 10:48 PM
Good drivers. pixie Multi-Way 11 27th June 2001 11:46 PM
