#31 |
Update. How does it look?
#32 |
Looking good!
The base seems awfully skimpy for the super high aspect ratio though. Hope there's no kids/pets to tip them.GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#33 |
I might add bigger footing and putt some ballast in it. Drawing is to get a idea of the design. All comments welcome.
No children or pets in the room. Door is locked. Having tube amps, you cant be to safe. Mark |
#34 |
Got a little done today. Son helped with the big sheets.
Btw, I went with birch ply instead of mdf. Heres a pic.
#35 |
Nice! I envy you, I'm having to cut/assemble/install a new gutter system.
![]() GM
#36 |
Dont fall off the roof!!! When I was a kid, we would jump off the roof with a tractor umbrella. Glad I didnt weigh much.
I was looking at the dims for the port. 3"radius x .075. 6" port looks large cut out. Mark |
#37 |
Can't, it's all ladder work.
Yeah, I 'run the numbers' for an alignment and it is what it is, but when I saw the cut wood, had to go back and check to make sure I hadn't screwed up. GM
#38 |
I was hoping I read the dims right. Feel better now.LOL.
Dont fall off the ladder. Mark |
#39 |
Got another question. Do you think its worth chamfering the back of the baffle/driver cutout?
Mark |
#40 |
Yes always!
Larry |
| Thread Tools | Search this Thread |
| NOS Mullard Double O EL34 NOS Pair Syl 6BQ5 EL84 | vintagekind | Swap Meet | 3 | 30th March 2012 03:49 AM |
| 4 Nos RCA 8417 tubes NOS | battradio | Swap Meet | 3 | 20th January 2012 01:02 AM |
| nos | Richiebuoy | Digital Source | 84 | 2nd February 2011 05:21 PM |
| Some ECC83's nos & 2 E280F's nos | Westerp | Swap Meet | 0 | 26th May 2009 10:00 AM |
| Why NOS? | preiter | Digital Source | 2 | 23rd May 2006 09:25 PM |
