Go Back   Home > Forums > > >
Wild Burro Audio DIY full range speakers from Wild Burro Audio Labs
Old 26th August 2012, 03:06 PM   #21
GM is offline GM  United States
GM's Avatar
You're welcome! Once broken in, I'm curious how tonally balanced they do organ, 'Dark Side of the Moon' and similar electronically enhanced music, i.e. how well does the room/boundary gain fill in below the MLTL's relatively high F3.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 26th August 2012, 05:00 PM   #22
opa1 is offline opa1  United States
opa1's Avatar
I was up late last night to listen without outside noise. I tried cd's Dark side of the moon, Diana Krall, America, Stones, Doors. Lp's Beethoven, Steely Dan, Led Zepplin, The Who, and Jefferson Airplane Surrealistic Pillow. All sounded good. Floyd, Krall, America, Beethoven and Airplane were the best. I have some organ solo based lp's. I'll try them.
I dont have measuring tools for actual measurements. To my ears, the room gain took the Lf rolloff quite low. Even at lower volumes. I've been using my tube amp on them. I'll get my Marantz ss out and try it. I'm sure the ss will find any problems if there are any.
Mark
Old 31st August 2012, 08:06 AM   #23
opa1's Avatar
Been playing the betsyk's alot. They are sounding even better. I've gone back and tried the betsy ob's. I do like the ob sound, but the mltl is still a better choice in my room. Clarity and solid bass.
Old 31st August 2012, 04:15 PM   #24
GM's Avatar
Old 31st August 2012, 06:56 PM   #25
MagnumOpus is offline MagnumOpus  Norway
Nice one!
Can't wait to get my boxes done. I have just finished sanding down the phaseplugs, thinking of getting som nice oilcoat finish on them.
"Simplicity is the key to brilliance"
Old 1st September 2012, 02:44 PM   #26
gfederys is offline gfederys  United States
Default What About....
I understand the BIB concept, but what about trying Betsy K's in some back horn loaded cabinets? Does anyone think that'll work? It looks like the QTS is too high. Thanx.
Old 1st September 2012, 07:19 PM   #27
GM's Avatar
No, it's not, but the lower its motor mass corner [2*Fs/Qes] due to higher Qts, the larger the filter chamber and throat required, ergo the horn. The BIB is a simple approximation, but gives you some idea of the size required if not built into a corner such as the 'little' EV, Klipsch offerings in the '50s for 40-60 Hz Fs drivers.
GM
MLTL- Betsy kHide this!Advertise here!
Betsy-K in a BR Karl71 Wild Burro Audio 11 27th July 2012 06:42 AM
WBAL Betsy-K 'small' ~40 Hz MLTL GM Full Range 3 5th June 2012 03:09 AM
Padding the Betsy-K Karl71 Wild Burro Audio 2 6th April 2012 02:50 AM
My betsy build fameless Wild Burro Audio 10 28th March 2011 08:38 PM
The Betsy Roushon Wild Burro Audio 5 11th June 2010 11:29 PM
