Go Back   Home > Forums > > >
Wild Burro Audio DIY full range speakers from Wild Burro Audio Labs
Old 21st August 2012, 12:50 PM   #11
fastbike1 is offline fastbike1  United States
It looks like the ends of your braces are beveled. Are you putting the ends into the corners? The bracing needs to stiffen and subdivide large panel areas, not corners. Ideally into non-symmetric sizes.
Originally Posted by opa1 View Post
Made some interlocking x braces 2.5x 3/4". Cut top covers.
I was so much older then, I'm younger than that now.
Old 21st August 2012, 03:45 PM   #12
opa1 is offline opa1  United States
opa1's Avatar
I'm glad I didnt glue them in.lol Making new ones today.
Old 21st August 2012, 11:39 PM   #13
opa1's Avatar
Made new braces today. Two 3.75x3/4 from top to bottom with 3/4x2.5 cross braces. All interlocked and glued in. Still waiting on ports from pe. Going to need a hand truck to move them.lol
Old 23rd August 2012, 03:54 PM   #14
GM is offline GM  United States
GM's Avatar
Are you saying to glue two 3 3/4" strips together. Then place it from top plate to bottom? I'm guessing it would go in the center of box. Or I can put two 3/4 x 2 1/2 x braces at Zd and Zp. Or do both?
No, I meant the stiffeners should be ~0.67x - 0.75x the internal cab height cut from either 1x3 stock or from scrap ply. Corner joints are ‘hot spots’ of rigidity, so no need to run the bracing the entire length and in theory it’s acoustically undesirable.
One would be glued on edge to each side wall and back and ideally offset in some golden or acoustic ratio to randomize [average out] panel resonances rather than sum them into a series of harmonic structures that may cause the cab to comb filter [‘sing along’] with the driver’s output.
If the cab’s panels are so large that dividing them in two yields one > ~12” wide, then a second set of vertical and/or ‘X’ frame braces is required. At this point, ‘window’ braces may be preferred from a construction POV.
The ‘X’ braces are tied to these at ~3rds and/or ~5ths to ensure the walls can’t ‘breathe’ regardless of driver, vent location. If the cab’s cross sectional area is > 12” square [> 144”^2], then do the same to the top and bottom plates as well as mass load them as required.
WRT vertical bracing to tie the top and bottom to the four sides, this is a good plan when the cab’s cross sectional area is > 12” square [> 144”^2] and again it ideally needs to be offset at some golden or acoustic ratio, so if also used as a driver brace, then ideally the driver should be offset on the baffle at the same ratio.
Since it’s also a good plan to offset the driver on the baffle to randomize its eigenmodes [standing waves], it seems reasonable that if the baffle is too narrow to offset the driver, then a centered vertical brace isn’t required either except as a driver support and even then it should be offset.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 23rd August 2012, 05:37 PM   #15
opa1's Avatar
I ran two vertical strips just outside the driver cutout from top to bottom. Then x braced at driver and port. Their all glued in so no changing now. Put acoustic foam on back, one side wall and top.
Old 24th August 2012, 05:28 PM   #16
MagnumOpus is offline MagnumOpus  Norway
Nice, I am about to build these myself, but I am still missing some tools.
Do you have the dims for the flush cutout? In metric? I would really appreciate it!
"Simplicity is the key to brilliance"
Old 24th August 2012, 07:43 PM   #17
opa1's Avatar
The cutout for flush mounting the BestyK is 1/4" deep x 8 5/16" dia. The cutout for the speaker is 7 3/8" dia. Metric is .625 deep x 211.138 dia. Speaker cut is 187.325. I cut the recess for the flush mount 1/4 deep. Then kept moving the jig smaller until the recess was 1/2" wide. Then cut the 7 3/8 cut.
I had to buy alot of tools. I bought some second hand. The jig I bought for the router sure made it easy to cut the port and speaker holes. Hope that helps.
Mark
BTW, I had 19mm plywood. You might have to adjust depth if you use thinner wood.
Old 25th August 2012, 01:35 AM   #18
opa1's Avatar
Got alot done today. Ports came in. Wires are run. Looks like a test run tomorrow. Still need sand and finish. Pics later.
Old 25th August 2012, 07:26 AM   #19
Mark
Thanks, really helps!
Old 25th August 2012, 08:09 PM   #20
opa1's Avatar
In room testing has started. Impressed, you bet!!! The bass is clear no adjustments needed. I tried a few of my stronger bass heavy lp's Just to see if they boom. Clean and precise. I have them weighted down with 14.5 lbs. each. The betsy k's are new so I'm going to play them for a few days. I made some mistakes here and there and had to redo. For the outcome it's worth the time and materials. This was my first full speaker build. I have to give thanks to GM for all the info and help. And thanks to Fastbike1 for catching a mistake. Now when are they going to be finished?
MLTL- Betsy kHide this!Advertise here!
Betsy-K in a BR Karl71 Wild Burro Audio 11 27th July 2012 05:42 AM
WBAL Betsy-K 'small' ~40 Hz MLTL GM Full Range 3 5th June 2012 02:09 AM
Padding the Betsy-K Karl71 Wild Burro Audio 2 6th April 2012 01:50 AM
My betsy build fameless Wild Burro Audio 10 28th March 2011 07:38 PM
The Betsy Roushon Wild Burro Audio 5 11th June 2010 10:29 PM
