BIB dimensions - Page 3 - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Wild Burro Audio
Wild Burro Audio DIY full range speakers from Wild Burro Audio Labs
Old 14th August 2012, 11:10 PM   #21
GM is online now GM  United States
GM's Avatar
Yes.
Closed pipes have peaks at its even harmonics and nulls at uneven harmonics with the 1st one damping the system at Fb [Fp] with the 3rd harmonic being approximately two octaves away and since the first one is so low, the 3rd is still a ‘biggie’. As you can see, the rest of the harmonic peak/null ‘train’ continues to decay away to near infinity [in theory AFAIK].
Of course some damping is required to smooth all this out and if a room mode peak/null should match up good enough with the speaker’s, then they can ~ cancel out at the Lp, so much less actual damping is required in practice.
In reality, what usually happens is that the room massively comb filters with highly resonant speakers and due to how we perceive the lower octaves it can sound much smoother, more coherent than an in-room measurement indicates.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 17th August 2012, 01:51 AM   #22
opa1 is offline opa1  United States
opa1's Avatar
Well all the dims are posted here now. I'm not going to be able to build it at this time. WAF stepped in. Since I like to eat home cooking, well. Anyway hope someone will build one. She did ok a smaller project.
Old 19th August 2012, 12:41 PM   #23
Based on my T/S measurements, the BetsyK will provide great response in 76 liters BR. Tune to ~45Hz. F3/F10 44/34, models for flat response. HAven't built them yet so no further comments.
I was so much older then, I'm younger than that now.
Old 19th August 2012, 04:14 PM   #24
opa1's Avatar
I went with MLTL's. 6.226ft^3, 48x21x13.5 od. Have flatpacks cut and ready to go.
AJ-Horn & BiB - ar some BiB "parabolic"? freddi Full Range 3 6th April 2007 03:09 PM
exact dimensions of a BIB fe167e AudioGeek Full Range 15 21st January 2007 10:40 PM
Exact dimensions for BiB with 40-1354? Spasticteapot Full Range 1 24th November 2006 10:22 PM
Which BIB Dimensions for this Pair of FE164-s? DMD Full Range 20 23rd December 2005 06:02 PM
Box dimensions Vivek Multi-Way 10 16th September 2001 08:02 PM
Copyright ©1999-2017 diyAudio
