Go Back   Home > Forums > > >
Wild Burro Audio DIY full range speakers from Wild Burro Audio Labs
Old 24th March 2012, 11:50 AM   #1
keantoken is online now keantoken  United States
keantoken's Avatar
Default Protection Grille
Hello. I was doing some sine sweep tests with the speakers and apparently it angered one of the cats... Resulting in a torn cone. It still works, but I am now using the one that was damaged in shipping. I guess the ripped one is now my testing speaker...
What I always wanted to do was get some good wire and make a slave's-wages protection grille. Too late for one speaker unfortunately.
The attached images show what I'm thinking of. I was wondering what the sonic caveats might be to this approach. Will the directional pattern change a lot? Will this kind of grille make differences that can be used to improve the sound quality? Am I insane?
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 26th March 2012, 10:26 PM   #2
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
Kean,
I haven't played with grills much (well, at all, really, aside from my very first speakers). I suspect that that much wire would affect the sound quite a bit more than a fairly transparent grill cloth. I have used one big, curved wire, and didn't hear much of a difference. Obviously, the potential effects are up in the treble. I'd wonder about keeping it pretty open in the center, but maybe a little denser towards the edge of the cone. Maybe you could build some sort of hybrid, with traditional grill cloth in the center? Without testing, though, its hard to know. For all I know, you'd find the effects to be positive!
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Old 17th April 2012, 04:28 PM   #3
keantoken's Avatar
Thanks for the info. I guess I'll just start by wrapping the wire from screw to screw, and see what happens.
Old 17th April 2012, 05:33 PM   #4
pjanda1's Avatar
The advantage of heavy-gauge wire is that it holds its shape. So, you can make and arc that sticks out in front of the speaker, thus providing more protection (keeping stuff farther away). When I did it, I used what we called "#9 wire" from our on-farm fence building supplies. It was really heavy galvanized steel, and looked pretty neat. FWIW, I used the B&W Silver Signature as inspiration.
If you are wrapping from screw to screw (and thus, right across the center), it would be easy to play with "phase plugs".
Paul
Old 18th April 2012, 06:29 AM   #5
norman bates is offline norman bates  United States
norman bates's Avatar
I have a message from a betsy owner saying that he didn't recommend phase plugs........
Protection GrilleHide this!Advertise here!
fostex grille - any good? woodturner-fran Full Range 15 11th December 2014 06:23 PM
Need advice on grille project cast55 Construction Tips 0 12th September 2010 06:43 AM
Custom Speaker Grille morfius Multi-Way 6 22nd March 2008 10:55 PM
Grille Beams stelleg151 Multi-Way 7 31st July 2006 04:31 AM
6.5" behind 4x10 grille curtis73 Car Audio 0 24th March 2005 08:32 PM
