Go Back   Home > Forums > > >
Wild Burro Audio DIY full range speakers from Wild Burro Audio Labs
Old 1st February 2012, 07:02 PM   #21
dave slagle is offline dave slagle  United States
Originally Posted by keantoken View Post
Have you determined whether the output impedance of the power supply affects the sound? After all the voicecoil and field coil work like a transformer and the field coil may behave differently if it has a high source impedance or low source impedance. One easy way is to use a LM337 CCS to power it instead of a voltage supply.
Hey,
Using a voltage source vs. a current source does make a difference in sound but thus fat I haven't put a finger on what it actually does since different field coils seem to respond differently. What differences I hear seem to be in the lower frequencies) The differences in sound can be quickly compared by using a CCS and then simply decoupling it with a cap.
Another fun thing to do is to share the supplies and this gives another variation on the sound (again I hear it mostly in the bass)
If the field coil is large enough to self-resonate, I wonder if it could cause oscillation for the amplifier?
not the amplifier, but field coil is an inductor and placing a current source in series with an inductor can lead to instability of the CCS.
Also, I keep wondering why manufacturers use resistive voicecoils when they could just use copper and an external resistor.
simply put the amp turns of the voice coil determine the efficiency of the speaker. The resistance is a byproduct of the turns and is a liability. Take a Lowther which has 62 turns. In order to get 8W out you need 1A of current which translates to 62 amp turns. a single copper foil turn would require 62 amps of current and the net result would be the same dissipation and the same heating.
dave
Old 1st February 2012, 11:53 PM   #22
keantoken is offline keantoken  United States
keantoken's Avatar
Thanks for your response Dave. I will try to make some worthwhile points with my limited knowledge.
You are right, I didn't realize the field coil could oscillate with the CCS. If only the bass is affected, then bypassing the coil with a small capacitor might remove the possibility of oscillation. I'm thinking 1n-100n.
I would imagine the voicecoil and field coil are coupled close enough to work like an impedance transformer. Therefore a field coil fed with low impedance would act like a shorting ring for the voicecoil. IIRC the new drivers use a shorting ring already, so this may be mitigating the effect of field coil drive impedance. I may be totally wrong here because I have not studied speakers, but if the shorting ring only affects high frequencies, then it would explain why it does not mitigate the effect of field coil impedance drive on the bass; if there were no shorting ring maybe the effect would be larger.
Then perhaps if the shorting ring is omitted, the field coil can be used to shape the electrical characteristics of the voicecoil. Perhaps a field coil with low enough internal resistance to perform the same function as a shorting ring would not have enough turns to produce the strong field needed. Perhaps a tapped field coil with different gauge wires would work.
- keantoken
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 6th September 2013, 06:35 PM   #23
StevenZ is offline StevenZ  United States
Shame these never became available. I would have loved to own some.
Old 6th September 2013, 07:34 PM   #24
ejfud is offline ejfud  United States
ejfud's Avatar
Wonder if Paul still has these or if they found there way to FNG Doug.
Gary
One good driver is all I need.
Old 6th September 2013, 07:49 PM   #25
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
Sadly for me, they found a home. I really enjoyed my time with them, but honestly, law school isn't super conducive to listening time. And, they weren't really mine to begin with.
It isn't as if making these is impossible. But, the parts are very expensive and they require a ton of labor. We're talking $2k per pair neighborhood retail.
But, for folks who are interested, I think Dave Slagle has the parts to build another pair. For the right price, he might even explain how to put them together
Paul
Old 15th September 2013, 01:03 AM   #26
d to the g is offline d to the g  United States
d to the g's Avatar
Originally Posted by ejfud View Post
FNG
Sadly, I had to look that up.
Wild Burro Field Coils!Hide this!Advertise here!
Visaton B200 Vs. Wild Burro Betsy... Manolo47 Full Range 11 3rd April 2013 08:11 PM
Wild Burro Betsy with Plugs. bigaudioscotto Full Range 5 10th October 2011 09:16 PM
Wild Burro Onken nesha Full Range 58 14th March 2011 11:24 AM
Wild Burro 20 (WB20) badman Wild Burro Audio 0 30th January 2011 03:02 PM
Wild Burro Lab pics pjanda1 Wild Burro Audio 17 12th November 2010 05:28 PM
