| Wild Burro Audio DIY full range speakers from Wild Burro Audio Labs |
#11 |
Legs (distance from the floor) are 10cm (4") , an I'll try 15 or 20 cm , for more clear bass...
#12 |
Start amount of wool, 200gr/box
#13 |
He, he..I had a visite yesterday, a friend who's been listening B&W CDM2 monitors for last 10 years. We listened K Melua and M Gardot, and his comment was - This is so much better than my speakers, smooth but goes deeper into the recording...-
But we did hear a boomy bass sometimes... Lazy that I am, haven't tried taller legs... |
#14 |
Nesha,
That's great! Getting boxes and rooms to get along can be tough. You might try experimenting with placement in addition to legs, and/or it could be that you need to alter the stuffing. Often it is all just a matter of experimenting until you get it right. I'm glad you are enjoying them so much overall! Paul Wild Burro Audio Labs - DIY Full Range Speakers |
#15 |
Yam-yam!
#16 |
This looks like an easy enclosure to build. Does the port run along the width of the cabinet?
Thanks....
www.hifiduino.wordpress.com |
#17 |
Port is round, simple circle onthe bottom, 8" (20cm) in diameter.I'm sorry I haven't built them with BBplywood in the first place...
#18 |
Ups, my mistake, port is 24 cm diameter, as on diagram.
| BetsyK Simple TL | pjanda1 | Wild Burro Audio | 13 | 7th January 2013 06:02 PM |
| What's the difference between a TL, a ML-TL and a TQWT? | Bricolo | Multi-Way | 82 | 28th August 2008 02:17 PM |
| ML-TL or ML-TQWT with very low Qt driver | Henkjan | Full Range | 6 | 29th September 2006 02:29 PM |
| What is the Q of a (ML)-TQWT, (ML)-TML, etc | Elam | Full Range | 0 | 18th June 2005 08:56 AM |
| Small box for FE103 - ML TL or ML TQWT? | ChuckT | Full Range | 15 | 28th July 2004 05:56 AM |
