My betsy build - diyAudio
Go Back   Home > Forums > Commercial Sector > Manufacturers > Wild Burro Audio
Wild Burro Audio DIY full range speakers from Wild Burro Audio Labs
Old 22nd December 2010, 11:57 PM   #1
Default My betsy build
The betsy's are complete! Thanks to Paul for the build tips and great customer service! I really like the sound, need to swap the Klipsch Heresy's back in to see who gets crowned king of my living room. Here's my equipment breakdown: main source is my computer using J. River Media Center playing .flac files, Chaintek AV-710 soundcard optical out, Firestone audio Spitfire DAC with the Supplier power supply, NAD 165BEE preamp, DIY Class D amp TK2050 from Helder-HiFi, NHT X1 crossover and A1 amp for the subs, and the subs are two Klipsch SW-10II's turned passive after their amps went bad. NHT says not to use the X1 with subs other than their evolution subs, but I haven't seen an NHT evo sub for sale anywhere, besides it sounds good to me. I did have the betsy's running into the X1 crossed at 80hz, but I've been running them full range and like the results. So, what are your thought's? Suggestions to improve the betsy's or my equipment set up? Paul suggests running a cap from the preamp to the amp. I'll need to look up the imput impeadence of the amp boards to find the correct cap value.
Old 23rd December 2010, 03:28 PM   #2
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
The high pass filter would be to lower distortion and improve dynamic range, but it is only a really good idea because he has subs below it! And my thinking is that when possible, a line level filter is better than speaker level in terms of sound and cost, and passive tends to beat active for the same reasons. Fameless, I didn't mention this in the email. But many sub amps have 24db/octave or 18db/octave lp slopes, so forcing the OB's to have a steeper roll off may also get a better blend with the sub(s).
Great pics, thanks for posting them! How quiet are those amps through the Betsy? I've done Sure boards with Meanwell SMSP's and found the noise to be borderline. Amazingly, my tube amps are pretty quiet.
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Old 23rd December 2010, 10:02 PM   #3
There's a little bit of hiss, but it isn't noticable one meter away from the drivers. They get plenty loud as well. With the heresy's I had to turn the volume up half way to get uncomfortably loud, the betsy's reach the same level with only a quarter turn.
Old 24th December 2010, 09:55 AM   #4
put a pot and try without a preamp ...how know ?
I build a lot of tripath sound very good but man the tubes....
Marry Christmas to all
Old 24th December 2010, 03:36 PM   #5
pjanda1's Avatar
Given that his pre drives both main and sub amps, I don't know if "passive" is a possibility. And it certainly wouldn't help my recommendation of a HP cap at line level!
Paul
Old 24th December 2010, 05:10 PM   #6
work very good with a tripath ,all the gain need , plus as at the input there is a cap for the bias of tripath input stage can be lower this for HP cap , better than have two in series
Old 24th December 2010, 07:53 PM   #7
pjanda1's Avatar
Its not just an issue of gain though. Keep in mind that the loads of the tripath and the crossover are in parallel. Either on its own may be fine, but together they may create a pretty tough load. I'm a big fan of passive pre amps and keeping the gain down, but when you start driving multiple amps, they make less sense. Which isn't to say that I haven't done it, but I'm thankful for my pre stage and occasional chip buffer to alleviate such concerns.
Paul
Old 24th December 2010, 08:04 PM   #8
you are right, but one eye to the source output , 47k on tripath and one eye on sub input impedence
Old 28th March 2011, 12:35 PM   #9
norman bates's Avatar
You could try a bigger ob.
I'm planning on a 5' tall ob using 3 sheets. Center baffle 12", left baffle 15", right baffle 19". The driver is 37" off the ground. 25" is too low for me, I've had fullrangers that low and didn't like it. But I see that in your setup, it is almost lined up with the center of the tv.
You could try some 20g magnet wire untwisted as speaker wire soldered directly onto the terminals.
You can make a foam box to go around the back of the driver.
Norman
Old 28th March 2011, 08:27 PM   #10
pjanda1's Avatar
Norman,
I agree that many folks, myself included, might like the drivers a little higher. I'd suggest that anyone make them as tall as they (and their partners) can tolerate. Tilting back (like the JE labs baffle) doesn't do much for me. You do make a good point about the TV though.
Are you thinking untwisted as a way to raise inductance in the speaker wire? That works well for speakers that are a little hot in the treble, but the Betsys shouldn't need it. Depending on the source of the hiss, it may help there. I tried clamp on ferrites with a chip amp I used to run. Didn't help much. A LP filter on the amp input did. But, I also suspect much of this noise is either in the chip itself or due to the power supply.
Any more specific suggestions on the foam box?
Paul
The Betsy Roushon Wild Burro Audio 5 11th June 2010 11:29 PM
50% off to take Betsy where she's never been! pjanda1 Wild Burro Audio 74 8th June 2010 04:42 AM
Freq. Resp. for the Betsy-K Karl71 Wild Burro Audio 3 11th May 2010 03:53 PM
Phase plugs for Betsy planet10 Wild Burro Audio 10 9th March 2010 01:59 AM
Betsy-K Impedence Karl71 Wild Burro Audio 1 7th December 2009 01:09 AM
Copyright 1999-2017 diyAudio
