Go Back   Home > Forums > Commercial Sector > Manufacturers > Wild Burro Audio
Wild Burro Audio DIY full range speakers from Wild Burro Audio Labs
Old 25th June 2011, 01:15 PM   #11
norman bates's Avatar
tweakk, what size cap did you use with that horny ribbon ?
Norman
Old 28th June 2011, 12:10 PM   #12
Taterworks's Avatar
That transmission line cabinet doesn't look like it will be very effective as a resonator, because there is a possible path that a pressure wave could take through the enclosure that would almost be a straight line, due to the way the folding is done, and the fluid flow (airflow) will naturally try to follow the path of least resistance, so the line will behave like it is much shorter than what was probably modeled in Hornresp. The pieces that make up the TL labyrinth look more like reflectors than flow guides. I anticipate this design will need lots of stuffing to perform optimally.
If it works, but you don't know why it works, then you haven't done any engineering.
Taterworks Audio (nothing for sale)
Old 14th April 2012, 01:36 PM   #13
e_fortier's Avatar
Originally Posted by tweakk View Post
More...
Beautiful enclosure, how do they sound.
I just bought a pair of Betsy K (they will be shipped next Monday) so I'm looking for some feedback on the sound if you can.
Thanks in advance,
Eric
Old 7th January 2013, 06:02 PM   #14
Nanook is offline Nanook  Canada
Nanook's Avatar
Default Betsy simple TL, really?
I think the posted graphic from Paul is more correctly a labyrinth. It reminds me of Lynn Olsen's Ariel in that it uses "offset" bracing or shelves to create it.
I would suggest considering the Demetri MLTQ from Planet10. I built a pair used with 8" FR drivers. It is very good, although a little large. In my case the FR still needs help from a decent tweeter. I have some Silverflute YAG 20-1/Dayton PT2C planar type tweeters that I'll add to them (simply mounted on top of the cabinets) or some Eminence 1-1/2" silk tweeters.
stew -"A sane man in an insane world appears insane."
Can anyone help TL or ML-TL for Alpair 10 _henry_ Full Range 3 31st December 2008 06:31 AM
What's the difference between a TL, a ML-TL and a TQWT? Bricolo Multi-Way 82 28th August 2008 02:17 PM
Simple, SIMPLE Digital volume control -_nando-_ Digital Source 5 21st December 2006 01:20 PM
tl, tl with other drivers or no tl at all? beamnet Multi-Way 14 20th January 2006 03:10 PM
Simple answer required for a simple question... rabbitz Multi-Way 4 31st August 2003 10:05 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 18.18%)
Copyright ©1999-2013 diyAudio
