Go Back   Home > Forums > > >
Wild Burro Audio DIY full range speakers from Wild Burro Audio Labs
Old 11th January 2011, 04:19 PM   #11
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
Note that the link is probably the only place you will find the woofer, as it was an OEM model. Not only would you need to purchase the exact woofer, but you'll need to duplicate the crossover. Notice that I'm also using a line level high pass on the fullranger (which is generally a good idea with any helper woofer).
Given your level of experience, I highly recommend using the proven baffles with the Alpha 15 or Goldwood 18. My route certainly sounds good, but is a bit more involved. Notice that there is a pair of Alpha 15s in the Swap Meet at a good price.
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Old 11th January 2011, 05:08 PM   #12
al3700 is offline al3700
Thanks again Paul. I guess I have a lot to learn.
Old 1st August 2011, 02:18 AM   #13
mashaffer is offline mashaffer  United States
Hey Paul;
Those M8 amps would be ideal for some current drive experiments that we discussed (quite) a while back. You could put a Betsy K (nice low Qms) on OB and compare the results with gNFB, the RH84 configuration and pentode mode with unbypassed cathode resistors and see what it does to the bass. Beyond that one would have to get fancy with current feedback methods.
Generic Signature
OB/amp project updateHide this!Advertise here!
3way OB project with Peerless & Fountek drivers fivestring Multi-Way 8 17th March 2009 11:45 AM
JBL 2226H & 2426H cd/2370 horn combo in OB project..? JandG Multi-Way 6 1st December 2008 07:40 PM
Sensitive Wide Range OB - Update - Tonemaster Magnetar Multi-Way 76 7th October 2008 12:15 PM
speaker project update kendt Full Range 0 29th January 2007 03:29 PM
Copyright ©1999-2017 diyAudio
