Go Back   Home > Forums > > >
Wild Burro Audio DIY full range speakers from Wild Burro Audio Labs
Old 16th December 2009, 03:47 PM   #1
Godzilla is offline Godzilla  United States
Godzilla's Avatar
Default Betsy/Boomer OB speaker kit
Hello Wild Burro Audio Lab fans!
Oftentimes simpler is better. Nothing is simpler than placing a Betsy on an open baffle to enjoy music. But the Betsy can use help in the lower octaves so I designed the Boomer. The Boomer is an easy way to add bass. Itís an Alpha 15 woofer mounted close to the floor thatís powered by an external subwoofer amp. While taking up the same amount of floor space, the addition of two 15 inch powered woofers really fills out the bottom octaves producing full, warm, rich bass thatís adjustable to taste using the amps separate volume and crossover controls. Once you listen to the Betsy with the Boomer you will find it very difficult to enjoy the Betsy, or just about any other speaker, without the added bass to round out the sound. If you have any questions about the Boomer donít hesitate to ask.
Open Baffle Speaker - Betsy and Boomer Open Baffle Speaker Kit
Godzilla
Old 16th December 2009, 07:00 PM   #2
adason is offline adason  United States
adason's Avatar
Hi Godzilla,
makes sense and looks great. Congrats. Any picture from the back?
ed
Old 18th December 2009, 12:00 AM   #3
Godzilla's Avatar
Here's a picture of the back with the tweeter in place. I must tidy up the wires! Without the tweeter the wiring is simple and clean direct from the Betsy to the amp and from the Alpha's to their amp.
Godzilla
Old 18th December 2009, 03:18 PM   #4
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
There is a surplus store out at this end of the state that carries reasonably priced motor run caps. A first order high pass could really extend the dynamic range of the Betsy +Boomer, and it would get the slopes of the woofer and FR a little closer by making the Betsy rolloff acoustically second order or so (6db rolloff from the baffle +6db from the crossover). I think 120uf would be about right on the Betsy, and the simplest way to accomplish that with common sizes appears to be two 60uf caps in series. A nice 60uf motor run is $6.50, and you'd need four. If anybody is interested, let me know and I'll grab you a quad. I'd be happy to pack 'em up for free, provided you reimburse me for the caps and shipping. Motor runs are big, but they are film in oil, which will sound much less bad than a cheap 'lytic. Motor runs also live forever, and if you don't like them on your speakers, they are great for tube amp power supplies. They are also much cheaper than the big polypro film speaker caps.
let me know if you are interested,
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Old 18th December 2009, 09:38 PM   #5
adason's Avatar
Paul,
are you sure about those motor run caps? Once I tried to use motor run cap, 4uF, on tweeter, it was big paper in oil cap, I thought it would be fine...but it sounded dull, for it was designed for 50/60Hz frequencies.
ed
btw: you most likely meant those caps in parallel
Old 18th December 2009, 10:25 PM   #6
pjanda1's Avatar
I did mean parallel. Thanks for your sharing your experience. I haven't tried motor runs in a crossover, but then, I haven't used a crossover for a few years! However, PIO's are known for having a signature. Newer motor runs are film and oil, so depending on your point of view, they might be preferable for speaker use. Some motor runs are also fused, which isn't good for audio. I can't imagine the film cap isn't preferable to 'lytics in the crossover, and I'd be surprised if they don't have a wider bandwidth than many of the caps often used in woofer crossovers. Folks tend to like motor runs as cathode bypass caps in tube amps, which is a wide bandwidth app. I would have a pair in that function if I could fit 'em! I've also seen them used as coupling caps. I will do a little research, as I'm sure folks have tried them in crossovers before. For $25, I think they are worth a shot.
Paul
Old 4th May 2010, 01:54 PM   #7
nicoch58 is offline nicoch58  Europe
ASC X386S sound good http://www.humblehomemadehifi.com/Cap.html
why not the betsy-K in OB as is not cover the full range, gain some db ! x 2w SET amp
and as not full range why not alnico (lower the xmax)?
just some ideas...
manu
PS shipping cost to italy for a pair of betsy?
Old 14th May 2010, 10:06 PM   #8
pjanda1's Avatar
Manu,
Sorry to get back to this thread so late! I missed seeing your questions. On the motor run front, I just built an amp that has a couple more (one as PS, one has preamp output cap) and it sounds great! I do hear a loss of resolution when I try large motor runs (120UF total) as a HP filter, but the distortion reduction may be worth it. And I suspect they sound better than most other reasonably priced options.
The Betsy-K could be made to work with a helper woofer, but you may have to cross the woofer over a little higher. Its lower Qts leaves you with less to work with around 150hz and down. Now, if your SET amp has a fairly high output impedance, it would raise the Q of the speaker/amp system, meaning that the BetsyK may be a fine choice.
You are right about the Alnico. The only motor I have access to on a reasonable budget would have not only a smaller Xmax, but a very limited Xmech. That isn't good for OB.
Shipping to Italy would run $55 USD. Let me know if you are interested!
Paul
Old 11th January 2011, 02:12 PM   #9
al3700 is offline al3700
Hi Godzilla
Is the boomer an Eminence Alpha 15?
Alan
Old 27th January 2011, 03:51 AM   #10
Godzilla's Avatar
Yup. But the amp on the ZillaAudio.com site powering the woofers may not be powerful enough for larger rooms. I have since swapped mine for a more powerful plate amp and the bass sounds better. I personally prefer the H-frames over flat open baffles but it might be my room.
Betsy/Boomer OB speaker kitHide this!Advertise here!
OB: Dark Star Shootout - Betsy vs. B200 rjbond3rd Full Range 46 16th November 2012 12:47 PM
Betsy-K Impedence Karl71 Wild Burro Audio 1 7th December 2009 12:09 AM
Betsy/Boomer OB Speaker Godzilla Full Range 7 19th November 2009 02:42 AM
LM4651 Boomer DjLeco Class D 10 3rd November 2006 10:44 AM
