Go Back   Home > Forums > > >
Wild Burro Audio DIY full range speakers from Wild Burro Audio Labs
Old 21st January 2010, 04:02 PM   #11
human.bin is offline human.bin  Italy
nice to know you decided to use it! so i'll know how it sounds before i buy it keep us posted on all the work!
Old 21st January 2010, 04:13 PM   #12
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
At this point, I'm planning to use it only on the woofers. The flexibility of DSP should make it fairly easy to match the woofers up to the combination of passive first order crossovers and acoustic rolloff I'm planning to use on top. Given that I'm only using it up to 150hz or so, I don't expect resolution to be a problem. The only question is whether I am smart enough to get the slope and phase right!
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
OB project: thinking out loudHide this!Advertise here!
Thinking about CNO-T25 pwef Multi-Way 1 25th March 2009 06:36 AM
Just thinking here. skooter Car Audio 9 29th November 2007 05:43 PM
I was thinking Hojvaelde Tubes / Valves 5 4th October 2006 07:53 PM
Thinking of starting a new project, needing some advice Jacobus Full Range 3 1st February 2006 09:28 PM
BridgeClone Questions (thinking out loud) PaulHilgeman Chip Amps 15 30th July 2003 09:59 PM
Copyright ©1999-2017 diyAudio
