Go Back   Home > Forums > > >
Wild Burro Audio DIY full range speakers from Wild Burro Audio Labs
Old 26th December 2012, 09:03 AM   #61
derwhalfisch is offline derwhalfisch  New Zealand
glt - Page 4, post #37 of this thread... the numbers there are all I had.
Old 26th January 2013, 03:33 PM   #62
pjanda1 is offline pjanda1  United States
pjanda1's Avatar
For those interested in a big floorstanding ported box for the BetsyK, this looks like a great option!
http://www.diyaudio.com/forums/full-...n-betsy-k.html
Paul
Wild Burro Audio Labs - DIY Full Range Speakers
Old 18th June 2013, 02:44 AM   #63
jhutka is offline jhutka  United States
jhutka's Avatar
Default BIB Calculator
There is a thread on the "Full Range" speaker forum that contains a BIB calculator.(Excel)
Thread is Titled:
"Terry Cain's BIB -why does it work and does anyone have those Fostex Craft Handbooks?"
Post Number 5017 from GM has the calculator to download.
JH
Old 8th January 2014, 09:49 PM   #64
gaston senac is offline gaston senac  New Zealand
Default BVR and WIBAQ
The BVR are here: http://www.diyaudio.com/forums/full-...r-betsy-k.html and in post #37 Enclosure designs for Burro Speakers
The WIBAQ are here: http://www.diyaudio.com/forums/full-...n-betsy-k.html
and here:DIY Hi-Fi: WiBAQ Speakers
I am building the WIBAQ, because the spreadsheet calculated BIB for the BetsyK where too wide and deep!
Old 8th January 2014, 10:34 PM   #65
pjanda1's Avatar
Yeah, the spreadsheet dimensions are big. I built my BIBs before GM came up with the formula, back when ScottMoose was calculating them one at a time. The dims I used (stated earlier) are lower volume and tuned lower. Theoretically, this results in a little less excursion control above the tuning frequency, and you can see that the bottom end is shaped a bit different. I had a pretty good sized room back then, and I got so much bass that I had to stuff the vents pretty thoroughly. I would only recommend the spreadsheet dims for someone with a huge room or a real love of bass.
Paul
Old 20th March 2014, 03:18 PM   #66
MagnumOpus is offline MagnumOpus  Norway
I found this on another forum:
Hawthorne Audio • View topic - Open box speakers
Scroll down a post or two. Give this some bling to the finish and they'd be to cold to hold :P
"Simplicity is the key to brilliance"
Old 4th September 2016, 07:13 PM   #67
Jpeezy is offline Jpeezy  United States
Originally Posted by pjanda1 View Post
I've got about twelve more minutes (before I need to head to a big band gig), so I'll make this quick. However, I have bunch of enclosure designs for my drivers that should be on my site. Here is a quick overview. I'll try to fill in pics and specs later on.
Betsy: The OB options are fairly straight forward, by herself or with a woofer. You can use her in a sealed box, but I'm not sure why you'd choose to do so. One unique option that came up in discussion is a small aperiodic box. It might be the smallest way to get a Burro speaker into your room, and with it, more sensitivity, dynamics and image size than you normally get in a bookshelf.
BetsyK: Sealed and vented options abound, but here are some more interesting things:
GM posted a 10:1 TQWT that looks great. If you can tolerate a wide cabinet with a decent sized footprint, it promises great performance and a very simple build. Specs to come.
Skinny quasi TQWT/TL: I designed a box for my brother in law after seeing the Zu Essence and liking the size. Mine is about 12x13x44". It is a very easy build with some advantages over a regular BR. I'm listening to a pair right now. I think this cabinet should be very, very popular. My in-laws are thrilled.
MooseBVR: ScottMoose was kind enough to simulate one of his double mouth BVR's for the BetsyK. I'll send you the dims if you want. I plan to build a pair. I meant to this fall, but the Skinny TQWT project got in the way.
BIB: My cabinets stayed in MN when I moved west. However, I can give you the specs I used (skinnier than the calculator produces). They are great fun.
I do plan to do a better, and more complete list than this thread. But, I wanted to get something fun up before folks get home from work!
Paul
hey can you post the dimensions for the scott moose BVR?
Old 5th September 2016, 07:09 AM   #68
This Post gives the dimensions;
This Post is someone's mockup...
This Post is a picture of my build.
I loved these BVR's. Truly. I'm using the same drivers in smaller ported boxes these days though...
All IME, IMO and IMU of course
Old 16th September 2016, 01:28 AM   #69
what size enclosure and port dimension
Old 16th September 2016, 04:34 AM   #70
GM is offline GM  United States
GM's Avatar
??? They are in the listed [rather hard to tell] hotlink, but clicking it I see it's not much help till you get to here, so wondering why it wasn't posted instead: http://www.diyaudio.com/forums/full-...r-betsy-k.html
But then scrolling down the thread there's newer versions with V7 apparently being the final, so hopefully the real hotlink: http://www.diyaudio.com/forums/full-...ml#post3542628
Sheesh!
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Enclosure designs for Burro SpeakersHide this!Advertise here!
my first DIY project, the Burro/Boomer? ..of_letters Full Range 14 19th May 2009 09:07 AM
Fostex Enclosure Designs rcayot Full Range 4 27th December 2007 11:14 PM
SoundStream Enclosure Designs Lost metal Car Audio 0 17th November 2005 10:10 PM
alternative enclosure materials or designs? diydave Multi-Way 17 27th October 2005 09:50 AM
Car Enclosure designs RaphTube Car Audio 2 18th May 2005 07:20 PM
