| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Vendor's Bazaar Commercial Vendors large & small hawking their wares |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
#21 |
Neu, Original, Grade A Panel
Samsung OR TOSHIBA Grösse: 15.4" Auflösung: WUXGA 1.920 x 1.200 Grösse: 331.2 x 207.0mm , Pixel Abstand: (mm) 0.173 Farben:262K Kontrast: 600:1 Helligkeit cd/m2) 175+ KM9E89BTVL HDMI KONTROLLER Set: Kontroller Board, Menü Board , Inverter Board , LVDS Kabel +Fernbedienung Specification for AD-board: Signal input: Analog RGB(0.7Vp-p),TTL Composite video signal (1.0Vp-p +/-5%) S-video(S-Y:0.714Vp-p +/-5%;S-C:0.286Vp-p +/-5% ![]() 2-facher Audio Input (PC Soundkarte& AV Audio input), HDMI YPBPR, SCART Video system: PAL , NTSC , SECAM; T V Bands: VHF-L:49.75-160.25 MHz VHF-H:168.25-450.25 MHz UHF:451.25-863.25 MHz VESA: DOS, VGA,SVGA,XGA,SXGA, WUXGA Color: 24bit Range of H FREQ 30-100KHz Range of V FREQ 56-75Hz Signal output: Double LVDS 10BIT Output Power for audio: 2x 10W OSD: AUTO/EXIT,VOL-,VOL+,POWER,CH-,CH+ MENU (A) OSD MENU: Kontrast , Hellikkeit, Volumen, Mehrsprachig TV: Kontrast , Helligkeit , Sättigung , Volumen, Auto-scan , Sprachen , Netzgerät Input: 12 V(+/-0.6V) Leistung: Normale Nutzung Spar Modus Stromverbrauch: 30W (ohne Dauerbelastung) Abmessungen: 258mm (L) x137mm (W) x29mm (H)
DIY LED projector carpow@126.com |
#22 |
What's included in the 1080p kits? does it come with the lenses, bulbs, etc?
#23 |
Anybody built one of the 1920*1200 kits yet? How difficult/easy would it be to source the extra parts, such as the lenses and whatnot? I can't really tell what you get in the kit and what else is needed.
I'd love to try one of these kits though... |
#24 |
15"4 Optic set
1 x Fresnel 500mm 1 x Fresnel 330mm 1 x lamp box 1 x triplet 450mm 1 x 180w/6K lamp 1 x 180w Electronics lamp power 2 x Fans 80MM.
| Thread Tools | |
| 10.6 1280x768 lcd kits for 720p Projector. | carpow | Group Buys | 3 | 1st June 2007 12:08 AM |
| Infocus Sp5000 720p Projector, 720P *NATIVE* | Mitch_eich | Swap Meet | 0 | 13th May 2007 04:36 PM |
| Page generated in 0.13768697 seconds (73.17% PHP - 26.83% MySQL) with 11 queries |
