NP D1 DAC clone with enhancement - Page 5 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 24th April 2007, 03:06 AM   #41
spencer is offline spencer  Hong Kong
Send a message via MSN to spencer Send a message via Skype™ to spencer
Ver 2 started singing and further testing in progress.
Old 24th April 2007, 03:07 AM   #42
One more photo
Old 24th April 2007, 05:35 AM   #43
Stuffing and Adjustment Procedures:
1. Solder resistors, LED and diodes
2. Solder film capacitors except the BIG 10uF cap
3. Solder all jumper pins
4. Solder IC sockets
5. Solder bead, inductors
6. Solder Pulse transformer
7. Solder all pots (VR)
8. Solder small E-caps (22uF to 330uF)
9. Solder Regulator Jfet / Transistors / TL431 etc.. (do not solder jfet IV fets)
10. Solder connectors if used
11. Solder big E-caps (1000uF and 2200uF)
12. Solder all relays
13. Solder IRF610/9610 with heat sink
14. Verify the +/- 20V regulator (across R59 and R60) is working and adjust the output voltage.
15. If cannot adjust the voltage to 20V, solder a 220k resistor and parallel to R47, R48, R65 or R66. Do this when needed.
16. Then solder the Jfet IV FETs section module by module.
17. Power up again and adjust Pot R1 until Point A to 10Vdc, Adjust Pot R2 until Point B is 0Vdc, Repeat adjustment on R1 and R2 when necessary.
18. Then adjust Pot R8 until voltage across R14 is 5Vdc.
19. Repeat to solder other Jfet IV section and adjust voltages as above.
20. Solder the LM317 and 337 with heat sink in pairs and verify the regulator output voltage is 5V +/-0.1V at the PCM63 IC socket positions.
21. Repeat and verify all regulators to PCM63 is either +5 or -5V.
22. Verify the +20/-20V regulators are still at correct voltage. This voltage should not change more than 0.2V or else something may be wrong.
23. Now solder the 7805 and 7808 in the digital sections and verify all output voltage correct. You can check voltage at the IC sockets pins to double confirm.
24. Solder the 8412/8414 chips in position. Plug in 5842 chip.
25. Short the pins for 8414 power to clock regulator. Also select the input jumper to RCA socket (right side two pins shorted).
26. Power up the digital section, the error LED should be ON after 1 second. Then inject a SPDIF signal to the RCA digital in socket, the Error LED should be OFF now.
27. Use a scope to check if there is pulsed at CLK, LE, DOL and DOR nets. If don’t have scope, use a DC voltmeter and check voltage is about 2.5Vdc.
28. Power down and go back to DAC section.
29. Plug in PCM63 first chip.
30. Verify the Iout is at 0V dc (point B), if not, fine tune the R2. Note that this voltage should not change much after the first adjustment. Check point A still at about 10V.
31. Repeat for other PCM63 one by one.
32. Then check the current drain at R81 and R82 (5.1 ohm resistors). The voltage drop across R81 is about 0.97V while the voltage at R82 is about 1.15V.
33. Solder the 4 BIG film caps 10uF.
34. If everything is fine, plug in transport and you should hear music from the output.
35. Perform normal testing with a test CD.
36. Warm up the set for 1 hrs and adjust the voltage at point A and B again when needed.
Notes:
1. The “+” mark on D10 LED is wrong polarity.
END
Old 24th April 2007, 01:19 PM   #44
Wave form at 100Hz, output voltage about 1.9Vrms single ended.
Old 24th April 2007, 01:21 PM   #45
Output at 20kHz. Output level at 1.73 to 1.68Vrms for left and right Single ended output.
Old 24th April 2007, 02:18 PM   #46
For those interested, can email me. 10 pcs board are still available and the rest already booked by other members.
Price of ver2 board is US$25. Shipping with registered mail is $8. Thus total will be $33.
8414 to 8412 converter board is $1.
I shall release a SM5847 to SM5842 converter board soon and price of this gold plated board is $5. Pins and 4 ceramic smd capacitors will be included. I shall post photo when I receive the chip and tested working. I am able to provide 6 SM5847 IC for sales and price is $20 each.
Selected parts are avaliable but with limited quantity. See list attached.
Thanks for all your interest.
Old 24th April 2007, 02:19 PM   #47
5847 to 5842 converter bare board.
Old 28th April 2007, 01:27 AM   #48
SM5847 converter board half done. Need to source a good pins and hope to finished it by Sunday or coming Monday.
Old 29th April 2007, 03:56 AM   #49
Still waiting for the pins!
Old 29th April 2007, 03:59 AM   #50
SM5847 from NPC.
Does anyone ever use enhancement-mode devices? keantoken Solid State 4 19th January 2009 10:52 AM
System Enhancement Help Victoria Subwoofers 1 12th January 2006 09:47 AM
Active Crossover And Sound Enhancement Units set Chip Amps 1 12th January 2005 11:32 AM
SubWoofer Enhancement Negative Design Analogue Source 0 31st December 2003 05:50 AM
Copyright ©1999-2017 diyAudio
