NP D1 DAC clone with enhancement - Page 24 - diyAudio
Go Back   Home > Forums > Commercial Sector > Vendor Forums > Vendor's Bazaar
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 26th January 2013, 07:34 AM   #231
spencer is offline spencer  Hong Kong
Send a message via MSN to spencer Send a message via Skype™ to spencer
Both J28 and J29 has no effect on WM8804 and DIR9001 converter board. They are only used for CS8412 and CS8414 chips.
For D1V3, J22 set to 16bit for RJ mode for SM5842 digital filter. J21 set to DEM LED off.
Old 29th January 2013, 10:55 AM   #232
REALLY A FANTASTIC IMPROVEMENT!!!!
OK, D1V3 (and D1V33 upgrade) has always been a great DAC, but now with WM8804 is better again in all the audible sensations!!
This upgrade is really a MUST!!
Thanks a lot Spencer!
Sincerely.
Davide.
Old 30th January 2013, 11:39 AM   #233
Stealth is offline Stealth  Slovakia
Stealth's Avatar
I've got a D1V33 (WM8804 upgrade) too. If anyone had the opportunity to compare D1V33 vs FDA-1B, are there big sonic differences between??
Old 2nd February 2013, 02:42 PM   #234
Spencer
I also like to upgrade CS8412 to WM8804 module
I use SDS Lab PCM63 dac http://www.quadesl.com/pdf/tube_dac.pdf but modyfied SM5843 to SM5842
would you confirm that wm8804 will work without problem with that dac
Old 28th March 2013, 11:52 AM   #235
Default J5, J6 and J7 switches
in my D1V3 (with D1V33 and WM8804 upgrade) I have wired J5, J6 and J7 (Polarity Select Phase, Jitter Select, Dither Select) to relative 2 way switches in the front panel of the box.
The question is:
Can I change the postions of the switches with the DAC powered-on during the listening? Or should be better do it with the DAC powered-off?
Many thanks in advance. Best regards.
Davide.
Old 28th March 2013, 01:16 PM   #236
carsten.witt's Avatar
Hi @all,
after a very long time the D1 is in his temporary housing.
The inside picture is not the actually, the output caps are now black gates.
Thanks Spencer for this DAC. The tests with "WM8804" and "NPC SM5842AP" comes later after enjoying this for now.
Does anyone ever use enhancement-mode devices? keantoken Solid State 4 19th January 2009 09:52 AM
System Enhancement Help Victoria Subwoofers 1 12th January 2006 08:47 AM
Active Crossover And Sound Enhancement Units set Chip Amps 1 12th January 2005 10:32 AM
SubWoofer Enhancement Negative Design Analogue Source 0 31st December 2003 04:50 AM
Copyright 1999-2017 diyAudio
